Old 10th September 2017, 10:53 PM
dd_wizard's Avatar
dd_wizard Offline
Re: MODSIGN: Couldn't get UEFI db list after 4.12 upgrade
Please add your information to the bug that antikythera linked in post #2. It's a kernel bug... Remember, it's the squeeky wheel that get greased! I just downloaded and installed kernel 4.12.11-200.fc25.x86_64 from koji, and the bug is still present.
dd_wizard
Old 13th September 2017, 08:43 PM
Kensey Offline
macosfirefox
Well, I'm seeing two problems reported here actually. Some people get these errors but their system still boots fine. Others, like myself, are getting these errors on boot and hard lockups. (In fact something appears to have nuked all the files in /boot/efi on my system -- 'rpm -Va' complains about them being missing...)
Are we sure that the hard-lockup issue is the same as the MODSIGN error issue?
Old 18th September 2017, 03:09 PM
mj5030 Offline
Is it possible that it is a bad or missing configuration in udev-rules in the initramfs?
[root ~]# dmesg | grep MODSIGN
[ 1.482919] MODSIGN: Couldn't get UEFI db list
[root ~]# dmesg | grep initram
[ 0.640562] Unpacking initramfs...
[root ~]# systemd-analyze
Startup finished in 1.989s (kernel) + 5.789s (initrd) + 16.185s (userspace) = 23.963s
[root ~]# dracut -f -v
dracut: Executing: /usr/bin/dracut -f -v
dracut: *** Including module: bash ***
dracut: *** Including module: systemd ***
dracut: *** Including module: systemd-initrd ***
dracut: *** Including module: nss-softokn ***
dracut: *** Including module: i18n ***
dracut: *** Including module: network ***
dracut: *** Including module: ifcfg ***
dracut: *** Including module: drm ***
dracut: *** Including module: plymouth ***
dracut: *** Including module: kernel-modules ***
dracut: *** Including module: kernel-network-modules ***
dracut: *** Including module: resume ***
dracut: *** Including module: rootfs-block ***
dracut: *** Including module: terminfo ***
dracut: *** Including module: udev-rules ***
dracut: Skipping udev rule: 40-redhat.rules
dracut: Skipping udev rule: 50-firmware.rules
dracut: Skipping udev rule: 50-udev.rules
dracut: Skipping udev rule: 91-permissions.rules
dracut: Skipping udev rule: 80-drivers-modprobe.rules
dracut: *** Including module: biosdevname ***
dracut: *** Including module: dracut-systemd ***
dracut: *** Including module: usrmount ***
dracut: *** Including module: base ***
dracut: *** Including module: fs-lib ***
dracut: *** Including module: shutdown ***
dracut: *** Including modules done ***
dracut: *** Installing kernel module dependencies ***
dracut: *** Installing kernel module dependencies done ***
dracut: *** Resolving executable dependencies ***
dracut: *** Resolving executable dependencies done***
dracut: *** Hardlinking files ***
dracut: *** Hardlinking files done ***
dracut: *** Stripping files ***
dracut: *** Stripping files done ***
dracut: *** Generating early-microcode cpio image ***
dracut: *** Constructing AuthenticAMD.bin ****
dracut: *** Store current command line parameters ***
dracut: *** Creating image file '/boot/initramfs-4.12.13-300.fc26.x86_64.img' ***
dracut: *** Creating initramfs image file '/boot/initramfs-4.12.13-300.fc26.x86_64.img' done ***
I would also like to point this out:
[ 1.483577] Loaded UEFI:MokListRT cert 'Fedora Secure Boot CA: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' linked to secondary sys keyring
It is happening roughly almost right after it spits out the MODSIGN error. I replaced the key with 'x' in case it was sensitive information.
412, list, modsign, uefi, upgrade
GRUB failure after Apper F22 kernel upgrade, dual boot Win8 UEFI itpwrusr Installation, Upgrades and Live Media 0 7th March 2016 09:55 PM
Install non-UEFI onto existing UEFI? BuckleSwasher Installation, Upgrades and Live Media 0 13th October 2015 10:13 AM
How to make grub on F17 (uefi w/ grub 1) boot windows 7 (uefi)? premudriy Installation, Upgrades and Live Media 4 21st August 2012 06:58 PM
Updated Bios - it wiped out UEFI menu entries - how can i reinstall Fedoras UEFI menu yossarianuk Using Fedora 1 3rd July 2012 06:59 PM
Why patch modsign disappeared ? Jeremy38 Security and Privacy 0 11th September 2009 09:26 AM
Current GMT-time: 17:46 (Sunday, 24-09-2017)
