Old 14th February 2012, 06:32 PM
VernDog Offline
Re: installing grub2 to MBR, looking to do this correctly.
su
grub2-mkconfig -o /boot/grub/grub.cfg
That should be
-o /boot/grub2/grub.cfg
edit: when you say remove sda1/2 do you mean remove the partitions? If so that won't effect Fedora or your boot, provided that grub is on the MBR.
My suggestions are always to run boot_info_script and analyse the RESULTS.txt file.
There's a wealth of information in the RESULTS.txt file.
Old 14th February 2012, 08:20 PM
PabloTwo's Avatar
PabloTwo Offline
"Registered User" T-Shirt Winner
Right. I just had the opportunity to try sudo grub2-mkconfig without the -o option, and with a pending new entry in my /etc/default/grub file. It did spin up a sleeping hdd, but all the script output landed on stdout, as stated. No more "suspicions" about that now.
Old 14th February 2012, 10:26 PM
LongTimeDabbler Offline
windows_7chrome
Originally Posted by g2nightmare View Post
Why is this necessary?
I think I've specified it before. I've changed my /etc/default/grub in the past on this partition and updated it sucessfully. I did it yesterday to make my grub echo "black people" when loading linux, it works just fine.
Maybe I should edit grub.cfg and remove the option from the list?
I plan on using gparted to delete my sda1 and sda2, my goal is to not be totally screwed when I delete it. I'm in the clear right now, right?
"make my grub echo "black people" "?
Whut?
Old 14th February 2012, 10:50 PM
PabloTwo's Avatar
PabloTwo Offline
Whut?
Why not? I think it's great that folks want to, and do, personalize their Linux installs. And there are so many ways to do it with Linux.
BASH:~/-> sudo grep -i echo /boot/grub2/grub.cfg
	echo	'Loading Linux 3.2.5-3.fc16.x86_64 ...'
	echo	'Loading initial ramdisk ...'
You can edit that file and make say any darn thing you want. I like it.
Old 15th February 2012, 12:27 AM
g2nightmare Offline
Here is my results.txt
Would anybody be so kind to clean this up a little, or is it fine?
Remember, I want to remove sda1/sda2 partitions (windows partitions) and extend that volume back on my linux partition.
Old 15th February 2012, 02:18 AM
VernDog Offline
The missing "??" partition is due to grub2 changes. Download the current boot_info_script git here:
wget -O bootinfoscript 'http://bootinfoscript.git.sourceforge.net/git/gitweb.cgi?p=bootinfoscript/bootinfoscript;a=blob_plain;f=bootinfoscript;hb=HEAD'
Old 15th February 2012, 04:56 PM
g2nightmare Offline
Ok, done.
Here is my new results.txt.
It currently looks for msdos3 ??
That is an issue right?
Old 15th February 2012, 05:09 PM
PabloTwo's Avatar
PabloTwo Offline
No, the "msdos3" is not an issue. It's part of the new grub2 speak.
BASH:~/-> grep msdos /etc/grub.d/*
/etc/grub.d/05_font_color:set root='(hd0,msdos5)'
/etc/grub.d/30_os-prober:      mach_device="`echo "${grub_device}" | sed -e 's/(\(hd.*\),msdos\(.*\))/\1s\2/'`"
In the above usage "(hd0,msdos5)", is the equivalent of /dev/sda5. No need to be concerned about this.
Old 15th February 2012, 05:13 PM
g2nightmare Offline
So I'm ok to remove sda1/sda2?
Old 15th February 2012, 05:22 PM
PabloTwo's Avatar
PabloTwo Offline
VernDog answered that same question in post #16. I'm not going to make any commitments to an answer for that myself.
Old 15th February 2012, 05:38 PM
g2nightmare Offline
I'm half awake. Didn't see that comment.
Old 15th February 2012, 06:02 PM
VernDog Offline
What do you mean remove sda1, sda2 ?
It looks like Vista is riding on those two partitions. First is the boot partition, the second is the Windows partition.
/dev/sda1 2,048 206,847 204,800 7 NTFS / exFAT / HPFS
/dev/sda2 * 206,848 649,106,324 648,899,477 7 NTFS / exFAT / HPFS
/dev/sda3 649,107,456 968,579,071 319,471,616 83 Linux
/dev/sda4 968,581,057 976,773,119 8,192,063 f W95 Extended (LBA)
/dev/sda5 968,581,120 976,773,119 8,192,000 82 Linux swap / Solaris
So what will you put in its place? Just use it as storage?
Your not needing Windows anymore, correct?
Old 15th February 2012, 06:12 PM
robertdaleweir Offline
Hi VernDog
Great script!
Robert :)
Kernel 4.11.12-100.fc24.x86_64 Gnome Software 3.20
CPU AMD FX-6300 Six Core AM3+
MoBo Gigabyte 78LMT-USB3 AMD760G AM3+ MicroATX
Memory 8 Gigs Gskill Ripjaw DDR3-1333 PC-10666
Old 15th February 2012, 06:54 PM
chrismurphy Offline
macoschrome
Based on the bootinfo script results, I don't see how anyone can say for sure you don't need sda1 because it's not clear exactly what it is. It's Windows Vista or 7 related, and the volume format is NTFS. That's about it. So it's not necessary for Fedora, it might be necessary or supplementary to Windows - like a recovery partition of some sort.
Because sda3 is ext4 and not LVM, you don't really have a way to recapture the space in sda1 by adding it to a volume group. So I don't really see the point in getting rid of sda1. If you want to recapture that space you need to move data around on the disk and I just don't see an advantage in going to that effort.
Old 15th February 2012, 07:15 PM
g2nightmare Offline
I was going to use gparted. I already made a boot disk for it, and I've shrunk my windows 7 partition (sda2) two weeks ago by like 100g. Grub still wroked. I believe if I wipe the drive, I can still add that volume to my fedora partition. I'm missing out on ~300 gigs here, so I really would like to go through the effort.
Well yeah, I want to wipe sda1 and sda2 into unallocated space, and then use it to extend my sda3 fedora partition.
correctly, grub2, installing, mbr
Installing grub2 on /dev/sdb after /dev/sda died jdc18 Using Fedora 3 11th December 2011 06:31 PM
upgarade 15 to 16 was good before installing grub2 gnulinux Installation, Upgrades and Live Media 1 5th December 2011 11:31 PM
[x86_64] Installing Grub2 on EFI Elv13 Mac Chat 1 24th March 2010 02:44 AM
Yum not installing/removing dependencies correctly srdempster Using Fedora 22 12th April 2008 03:32 PM
not installing correctly? mcmischief Installation, Upgrades and Live Media 2 3rd September 2007 08:07 AM
Current GMT-time: 17:45 (Sunday, 24-09-2017)
