View Poll Results: Did it work for you
Yes 459 48.57%
No 343 36.30%
Nearly worked 143 15.13%
Voters: 945. You may not vote on this poll
  #151
Old 21st June 2007, 07:43 PM
DanMachado Offline
Confusion...
I am nearly to install FC6 in a lapto with a 32-bit architecture (intel core, dual, etc processor) I do not have any experience of installing OS...
So, will I have the problem about the wrong kernel?
Does "When the booting the CD (or DVD) enter the following at the boot prompt: linux i686" (http://www.mjmwired.net/resources/mj....html#problems) mean that in some moment of the installation the option will appear, and then I have to type "linux i686"?
Regards.
DanMachado
Old 21st June 2007, 07:50 PM
ramasees
Guest
Posts: n/a
i think if i remember correctly press f2 then type linux i686 then enter
Old 21st June 2007, 08:12 PM
DanMachado Offline
Well well I hope that you have a good memory!
Cheers!
Old 21st June 2007, 08:17 PM
leigh123linux
Guest
Posts: n/a
Cheers!
Well his memory is good
Old 21st June 2007, 08:43 PM
ramasees
Guest
Posts: n/a
thanks leigh and thats after a beer,have you had any flooding there pretty wet here in mids
Old 21st June 2007, 08:47 PM
leigh123linux
Guest
Posts: n/a
It's been dry here today but will had quite a bad storm at the weekend but no flooding.
Old 22nd June 2007, 02:02 PM
swa_1101 Offline
Hi, but have any kmod-fglrx working with kernel x86_64 3228 ?
I have install ati-driver from freshrpm, when it finished, reboot computer and I can not start X, error occur, It auto change xorg.conf back as fresh xorg.conf.
Old 22nd June 2007, 03:49 PM
leigh123linux
Guest
Posts: n/a
I will try and compile some for the new kernel and post them on post #2
I didn't need to compile any , I managed to find some for you
http://mirror.atrpms.net/livna/fedora/testing/7/x86_64/
Old 22nd June 2007, 05:07 PM
leigh123linux
Guest
Posts: n/a
Here you go ( I found some )
su
mkdir /home/*/livna
cd /home/*/livna
wget http://mirror.atrpms.net/livna/fedora/testing/7/x86_64/kmod-fglrx-8.37.6-2.2.6.21_1.3228.fc7.x86_64.rpm
wget http://mirror.atrpms.net/livna/fedora/testing/7/x86_64/xorg-x11-drv-fglrx-8.37.6-1.lvn7.x86_64.rpm
wget http://mirror.atrpms.net/livna/fedora/testing/7/x86_64/xorg-x11-drv-fglrx-libs-32bit-8.37.6-1.lvn7.x86_64.rpm
wget http://mirror.atrpms.net/livna/fedora/7/x86_64/livna-config-display-0.0.12-1.lvn7.noarch.rpm
rpm -i *
service fglrx restart
fglrx-config-display enable
Old 22nd June 2007, 06:09 PM
swa_1101 Offline
[root@localhost SWA]# service fglrx restart
bash: service: command not found
I could not continue!
When I restart computer it is not start X, same as my last post!
Old 22nd June 2007, 06:19 PM
leigh123linux
Guest
Posts: n/a
sorry you need to be full root
su -
1. Did you edit your xorg.conf as described in section 3 ? of post #1
2. Did you remember to downgrade xorg . ?
if the above steps fail post the output from
cat /var/log/Xorg.0.log | grep EE
and
cat /var/log/Xorg.0.log | grep WW
Old 22nd June 2007, 06:44 PM
swa_1101 Offline
Wink
All is Done but It is same!
[root@localhost SWA]# cat /var/log/Xorg.0.log | grep EE
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(II) Loading extension MIT-SCREEN-SAVER
(EE) AIGLX: Screen 0 is not DRI capable
[root@localhost SWA]# cat /var/log/Xorg.0.log | grep WW
(WW) No monitor specified for screen "Screen0".
(WW) No FontPath specified.  Using compiled-in default.
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(WW) RADEON(0): Unknown DDCType 5 found
(WW) RADEON(0): LCD DDC Info Table found!
(WW) RADEON(0): Failed to detect secondary monitor, MergedFB/Clone mode disabled
(WW) RADEON(0): Direct rendering disabled
(WW) <default pointer>: No Device specified, looking for one...
Old 22nd June 2007, 06:48 PM
swa_1101 Offline
Here is my xorg.conf before I reboot computer
# Xorg configuration created by system-config-display
Section "ServerLayout"
	Identifier     "single head configuration"
	Screen      0  "Screen0" 0 0
	InputDevice    "Keyboard0" "CoreKeyboard"
	InputDevice    "Synaptics" "CorePointer"
EndSection
Section "InputDevice"
	Identifier  "Keyboard0"
	Driver      "kbd"
	Option	    "XkbModel" "pc105"
	Option	    "XkbLayout" "us"
EndSection
	Identifier  "Synaptics"
	Driver      "synaptics"
	Option	    "Device" "/dev/input/mice"
	Option	    "Protocol" "auto-dev"
	Option	    "Emulate3Buttons" "yes"
EndSection
Section "Device"
	Identifier  "Videocard0"
	Driver      "fglrx"
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Videocard0"
	DefaultDepth     24
	SubSection "Display"
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Extensions"
Option "Composite" "False"
EndSection
Section "ServerFlags"
Option "AIGLX" "off"
EndSection
Section "DRI"
Mode 0666
EndSection
Old 22nd June 2007, 07:11 PM
leigh123linux
Guest
Posts: n/a
EndSection
	Driver      "kbd"
EndSection
	Driver      "synaptics"
EndSection
Section "Device"
	Driver      "fglrx"
EndSection
Section "Screen"
	Device     "Videocard0"
	DefaultDepth     24
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
EndSection
EndSection
Section "DRI"
Mode 0666
EndSection
Ok try this xorg.conf
Identifier "Default Layout"
EndSection
EndSection
Driver "kbd"
EndSection
Driver "synaptics"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "auto"
ModelName "auto"
Option "DPMS"
EndSection
Section "Device"
Driver "fglrx"
EndSection
Section "Screen"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
EndSection
This should say fglrx not radeon
Old 22nd June 2007, 07:27 PM
swa_1101 Offline
Hi, I have try to replace your xorg.conf but it is also failed!
I have a question: I can not do this because I have a new version 1.2.0-9 that can not remove
rpm -U --oldpackage xorg-x11-server-Xorg-1.2.0-6.fc7.x86_64.rpm
So if I do not try it, have any wrong about can not start X?
ati, fglrx, howto
ATI Catalyst fglrx driver manual install on Fedora 12 Jeff72 Guides & Solutions (Not For Questions) 15 13th August 2010 09:17 PM
ATI Catalyst™ Display Driver v9.12 rich52 Hardware & Laptops 1 31st December 2009 05:59 AM
HOWTO - make less noise from video card while using fglrx driver multescugeorge@ Guides & Solutions (Not For Questions) 2 3rd October 2009 08:02 AM
ATI Catalyst 9.x fglrx driver manual install on Fedora 11 Jeff72 Guides & Solutions (Not For Questions) 25 30th August 2009 08:29 PM
Current GMT-time: 05:43 (Saturday, 23-09-2017)
