Old 12th April 2017, 02:06 PM
zakoasia Offline
Re: poor quality sound,no loudness terratec aureon 5.1 PCI
Line in M give: line in, rear outp, bass outp.
Mic in mo give: mic in, center L/F.
For the 2 I can't set the level and if I press M it doesn't change.
sorry for my bad english, thanks for your understanding....
Old 12th April 2017, 02:15 PM
gordon64
Guest
Posts: n/a
it will be a little confusing because we are using both an alsa method and a pulseaudio method, I actually wanted to pulseadio but "bass out" is too tempting
Ok use arrow keys to get to line and press either up or down arrows to set to bass output
press the escape key
we may need to set up a 'rc.local' systemd file but I am used to the old way.
hopefully if you log out and log back in.......the alsamixer control stays on bass out?
and do you then get sound to bass?
Old 12th April 2017, 02:21 PM
zakoasia Offline
Ok changed the line to "default-channel-map = front-left,front-right,rear-left,rear-right,center,subwoofer" , saved log out and log in but it's the same. No subwoofer...
Old 12th April 2017, 02:25 PM
gordon64
Guest
Posts: n/a
which hole is the sub-woofer plugged into?
2) try the alsamixer setting post 17
Old 12th April 2017, 02:40 PM
zakoasia Offline
Tried the setting post 17. Didn't change, I'm going mad . Sorry I bother you with my problem
Old 12th April 2017, 02:42 PM
gordon64
Guest
Posts: n/a
ok time for bed hopefully we can look at the bass out issue later
maybe some one else can help?
Old 12th April 2017, 02:50 PM
zakoasia Offline
I have plugged the black on the green hole, the orange on the green and the green with green like they say (terratec).
The black is in the middle of the orange and green
---------- Post added at 01:50 PM ---------- Previous post was at 01:47 PM ----------
Thank for trying to help me if you lived in france I would pay you a shot . If I find the solution I'll post it here, thank you very much Gordon64
Old 12th April 2017, 04:56 PM
zakoasia Offline
windows_7firefox
It's harassment lol, I know where you are it's time sleeping...In the software from terratec under seven, there's a option for swapping center with bass/subwoofer and if deactive this option I have the same sound that I have under fedora. ie the sound is flat and poor.
It's in french but I make screenshot perhaps it can help to understand where is the problem with fedora?
https://servimg.com/view/18670008/20
https://servimg.com/view/18670008/21
Old 13th April 2017, 01:21 AM
gordon64
Guest
Posts: n/a
sorry I don't understand what you are trying to show me. Windows layout is not going to help us.
but I did find the English pdf for your card and make some comments
http://terratec.ultron.info/Audio/Au..._Manual_GB.pdf
page 4 order is pink blue 3xgreens 2x spdif
page 7 is the order they want......ignoring its in black and white, the holes are only the green holes
so I think you are saying you have:
orange jack, black jack and green jack....only to green.
http://imgur.com/a/mGzS2
back to alsamixer and try this order
a) when you first look at it, is line volume 81 showing MM or green?
b) arrow to it and press m to unmute it if is shows MM.....but tell us as I think you may have already tried in the past?
3) now find the cable to your real sub woofer. Pull out all other jacks so I think that means you have green jack to the third green, the green closest to the Pdif.
do you get bass with only one jack connected?
Old 13th April 2017, 06:32 AM
gordon64
Guest
Posts: n/a
Ok I may be wrong with your order but I think your order is wrong.
if we start at the pink hole the green holes are
green1
green2
green3
so far so good.
Now I translated your hole description with at least one thing for sure
you say green2 has a black jack
https://en.wikipedia.org/wiki/Sound_card
we can say they claim
lime green (green jack) goes to front
black goes to rear....................................green2
orange jack goes to sub-woofer........I claim that is green3
but I think your order is currently orange black green
and it should be
green black orange
http://imgur.com/a/zeWF4
2) of course the colour of the jack is not really important as long as you can follow the lead to the corrrect speaker.
but lets confirm your true jack to green holes please.
I am hoping we have set up Pulseaudio for 6 channel and the only thing we might need is to swap the orange with the green
Good luck
Old 13th April 2017, 12:37 PM
zakoasia Offline
Hello Gordon64 ! You have found where was the problem...I have bass now !!!!!
You know what? I'm ashamed...when you told me that the order is wrong I looked to the pc connections and jacks are ok. But when I look to the speakers where are holes for jacks ,the surround was inverted with center.
That's why under windows I had to invert center with sub to have bass.
I thank you infinitely, now I have bass. Real sound!!! 10000000000000000etc...thnx
Now I have to post for an other problem with wifi but not here.
Old 13th April 2017, 02:33 PM
gordon64
Guest
Posts: n/a
no worries you can mark it as solved now.
2) optional change your pulse audio config file so that you remove the ; and change the default value from 41000 (41k)
to 48k
default-sample-rate = 48000
install htop and then check your CPU consumption for pulseaudio and whatever media player you use.
its optional but your sound card can do it
aureon , c-media , loudness , pci , poor , quality , sound , surround , terratec
Sound quality is poor tech291083 Using Fedora 5 11th June 2013 01:29 AM
Cannot use digital output with Terratec Aureon 5.1 PCI Gamma746 Hardware & Laptops 2 8th April 2008 01:59 AM
Terratec Aureon MKII USB - don 't understand at all blowball Hardware & Laptops 1 14th February 2007 03:03 PM
poor sound quality Kingtu Using Fedora 2 21st August 2005 06:08 AM
No sound with TERRATEC Aureon Space in FC3 kosmyn Hardware & Laptops 0 25th December 2004 11:38 PM
Current GMT-time: 06:31 (Saturday, 21-10-2017)
