Old 25th August 2017, 09:26 PM
antikythera Offline
Re: install via usb -- where is the usb link to dl file onto usb?
Hi, possibly but it depends on the EFI boot order set by Mint. so pressing Fn+F2 doesn't work to get into UEFI firmware settings either?
Can you get into a terminal session with mint before it freezes or crashes? if so see if the efibootmgr is installed. either with root rights or sudo run efibootmgr
usage: efibootmgr [options]
	-a | --active         sets bootnum active
	-A | --inactive       sets bootnum inactive
	-b | --bootnum XXXX   modify BootXXXX (hex)
	-B | --delete-bootnum delete bootnum
	-c | --create         create new variable bootnum and add to bootorder
	-C | --create-only	create new variable bootnum and do not add to bootorder
	-D | --remove-dups	remove duplicate values from BootOrder
	-d | --disk disk       (defaults to /dev/sda) containing loader
	-r | --driver         Operate on Driver variables, not Boot Variables.
	-e | --edd [1|3|-1]   force EDD 1.0 or 3.0 creation variables, or guess
	-E | --device num      EDD 1.0 device number (defaults to 0x80)
	-g | --gpt            force disk with invalid PMBR to be treated as GPT
	-i | --iface name     create a netboot entry for the named interface
	-l | --loader name     (defaults to "\EFI\fedora\grub.efi")
	-L | --label label     Boot manager display label (defaults to "Linux")
	-m | --mirror-below-4G t|f mirror memory below 4GB
	-M | --mirror-above-4G X percentage memory to mirror above 4GB
	-n | --bootnext XXXX   set BootNext to XXXX (hex)
	-N | --delete-bootnext delete BootNext
	-o | --bootorder XXXX,YYYY,ZZZZ,...     explicitly set BootOrder (hex)
	-O | --delete-bootorder delete BootOrder
	-p | --part part        (defaults to 1) containing loader
	-q | --quiet            be quiet
	-t | --timeout seconds  set boot manager timeout waiting for user input.
	-T | --delete-timeout   delete Timeout.
	-u | --unicode | --UCS-2  handle extra args as UCS-2 (default is ASCII)
	-v | --verbose          print additional information
	-V | --version          return version and exit
	-w | --write-signature  write unique sig to MBR if needed
	-y | --sysprep          Operate on SysPrep variables, not Boot Variables.
	-@ | --append-binary-args file  append extra args from file (use "-" for stdin)
	-h | --help             show help/usage
You can use it to remove corrupt entries, set the next boot device etc.
  #17
Old 25th August 2017, 10:56 PM
jpenguin Online
Originally Posted by dorahard View Post
then would an external cd drive with fedora 100% for sure auto boot
Unlikely, can you disconnect the boot drive[
No real ideas though, https://is.gd/5KnRRY IMG]https://uploads.tapatalk-cdn.com/20170825/8b45b3314f0284f8ae21a533c701e2b0.jpg[/IMG]
Sent from my SM-G930R4 using Tapatalk
  #18
Old 27th August 2017, 12:40 AM
dorahard Offline
Banned
windows_98_nt_2000chrome
i dont understand what you mean by 'boot drive'
are you referring to the hard drive? if so, this laptop is impossible to open and i have no tools
https://www.youtube.com/watch?v=UP057Eu56co
---------- Post added at 11:36 PM ---------- Previous post was at 11:34 PM ----------
is there no other common solutions when there's no way to get into bios? and no boot hotkeys work?
  #19
Old 27th August 2017, 01:07 AM
jpenguin Online
So, neither fn-f2 or fn-f12 work? How far will Mint boot? https://forums.lenovo.com/t5/Lenovo-...ios/m-p/896225
  #20
Old 7th September 2017, 11:04 AM
N8tiv Offline
windows_98_nt_2000firefox
Smile Re: install via usb -- where is the usb link to dl file onto usb?
* where's the iso link?
there's a .exe dl link on https://getfedora.org/en/workstation/download/
but as said, after it installs, it never opens when i try to open it (on win10)
right click on the executable, click on properties…
Then check the box next to, "Unblock"…
Then click on "apply"…
right click on the executable again, then click on "run as administrator"…
Don't forget to disable "UEFI" in your bios… Make sure your machine is in, "Legacy Mode"…
Hope either of these help… :-)
ASUS ROG G75VX 17.3" Notebook i7-3630QM 2.40Ghz
SAMSUNG 850 EVO 2.5" 1TB SATA III, 5400 RPM 1TB HDD
G.SKILL Ripjaws Series 24GB (3 x 8G) 204-Pin DDR3 SO-DIMM
Nvidia GeForce GTX 670MX 3gb dedicated card
LXDE,WINE,Dragon NaturallySpeaking 12.5
  #21
Old 7th September 2017, 04:40 PM
GallComp Offline
Nuke 'em Alfred! Administrator - Starring in Bill & Steve's Bogus Journey
macoschrome
And this has been too long for comfort when is clear that the OP doesn´t have the required knowledge to follow any of the instructions, that or we are being played by a troll.
In any case, let´s end this, and hope for the user to find his-her answers bothering someone else.
Thread Closed.
"Since when has the world of computer software design been about what people want? This is a simple question of evolution. The day is quickly coming when every knee will bow down to a silicon fist, and you will all beg your binary gods for mercy. "
BILL GATES...
Closed Thread
file, install, link, usb
file not found while using make: symbolic link errors Fahim Programming & Packaging 6 11th October 2011 04:49 PM
glibc_2.0 not defined in file libc.so.6 with link time reference ar_m_in Using Fedora 13 14th July 2007 04:53 AM
D-Link DGM-530T Install help chriscraig Hardware & Laptops 2 12th September 2006 11:47 PM
make a symbolic link file with parameters jiawj Using Fedora 6 3rd November 2004 08:47 AM
Current GMT-time: 03:10 (Sunday, 24-09-2017)
