  #61
Old 10th March 2009, 09:55 AM
leigh123linux
Guest
Posts: n/a
Originally Posted by bigmacbb63 View Post
No, Leigh my hardware is 64 bit
bigmac
You run a 32 bit O/S so you need the i386 plugin .
[leigh@localhost ~]$ uname -m
x86_64
Old 10th March 2009, 09:57 AM
leigh123linux
Guest
Posts: n/a
Originally Posted by Jussarian View Post
Hi
I am following the instructions in post 1, but am getting this error message (several times):
--2009-03-10 09:12:42--  (try:12)  http://www.dfm.uninsubria.it/compiz/fusion-testing/flashplayer.x86_64/flash-plugin-10.0.22.87-1.x86_64.rpm
Connecting to www.dfm.uninsubria.it|1.0.0.0|:80... failed: Connection timed out.
Retrying.
Any work-around for this at all?
BTW thanks for the Nvidia driver instructions, they worked just fine.
The download command work here OK.
[leigh@localhost ~]$ wget http://www.dfm.uninsubria.it/compiz/fusion-testing/flashplayer.x86_64/flash-plugin-10.0.22.87-1.x86_64.rpm
--2009-03-10 08:57:19--  http://www.dfm.uninsubria.it/compiz/fusion-testing/flashplayer.x86_64/flash-plugin-10.0.22.87-1.x86_64.rpm
Resolving www.dfm.uninsubria.it... 193.206.162.138
Connecting to www.dfm.uninsubria.it|193.206.162.138|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 3715006 (3.5M) [application/x-rpm]
Saving to: `flash-plugin-10.0.22.87-1.x86_64.rpm'
100%[======================================>] 3,715,006    674K/s   in 5.5s
2009-03-10 08:57:25 (655 KB/s) - `flash-plugin-10.0.22.87-1.x86_64.rpm' saved [3715006/3715006]
Old 10th March 2009, 11:34 AM
bigmacbb63's Avatar
bigmacbb63 Offline
Hi leigh,
I am using an AMD64 machine with 2 gig ram; 160 gig hdd,
all software is 64 bit.
bigmac
Old 10th March 2009, 11:44 AM
leigh123linux
Guest
Posts: n/a
Hi leigh,
bigmac
Yeah right
uname -m is:
i686
bigmac
Old 11th March 2009, 06:39 AM
Lx_rules's Avatar
Lx_rules Offline
I have a Dell 1501 Inspiron with FC10 on 64. The flash plugin installed ok, but on some sites like megavideo, all videos don't play OK. I see videos a bit like slow motion. On youtube they play OK. Can anyone help me? Thanks !
Old 11th March 2009, 10:59 AM
Lx_rules's Avatar
Lx_rules Offline
Can someone try to see if on megavideo the flash plugin works ok?
Fujitsu Amilo Li 3910 and Mivvy L310 running FC14
Old 11th March 2009, 11:26 AM
Demz
Guest
Posts: n/a
Hi leigh,
bigmac
you probably have the Fedora10 32bit release running on your 64bit system
Old 11th March 2009, 05:20 PM
eyklidis Offline
Thumbs up Working with YouTube
Hello there
I just wanted to say thanks for this .rpm
Until yesterday i didn't had sound in youtube videos ... Following the leigh123@linux message on removing the existing flash-plugin installed from autoten script and installing this .rpm i can say it works as i wanted
Fedora 10 x86_64 AMD64 Turionx2
Old 13th March 2009, 09:14 AM
Smurf27 Offline
Originally Posted by leigh123@linux View Post
su
yum erase flash-plugin nspluginwrapper*
yum --nogpgcheck install flash-plugin-10.0.22.87-1.x86_64.rpm
I Have just installed this but I still have no shockwave on miniclip.com
how do I install shockwave??
Old 13th March 2009, 09:45 AM
Demz
Guest
Posts: n/a
you cant, not on linux you can only install Flash-plugin
Old 27th March 2009, 07:43 AM
Lopezadl2ian's Avatar
Lopezadl2ian Offline
I have made a rpm for the new 64 bit plugin
su
It should work for any version of Fedora
Do you have a link for 32-bit version? Thanks.
Old 27th March 2009, 09:05 AM
Demz
Guest
Posts: n/a
why would he need to provide that when there is one in FEDORA FAQ link ? http://www.fedorafaq.org/#flash
Old 5th April 2009, 11:18 PM
JoeF Offline
su
wget http://www.dfm.uninsubria.it/compiz/...7-1.x86_64.rpm
Must say thank you. This worked great when several others did not.
JoeF
Old 6th April 2009, 06:12 AM
brandon88tube Offline
I must ask, why is it that this flash plugin killing my cpu if the flash plugin I used in ubuntu 64-bit didn't? I know we are talking about two different distros here and that one is debian based and the other red hat, but come on. I don't remember exactly what plugin ubuntu was using because it automatically found it for me through the search and I installed it (yeah I like it simple).
Old 24th April 2009, 05:14 PM
Magickman's Avatar
Magickman Offline
Thank you, leigh123@linu. I was getting tired of waiting forever for a video to start, now it starts almost immediately. A big star for you.
flashpluginx8664rpm , obsolete
New x86_64 adobe flash plugin (alpha) G3R Using Fedora 53 10th November 2011 02:12 AM
flash-player plugin for x86_64? legumes Using Fedora 4 21st September 2011 11:24 PM
F11 x86_64, Firefox 3.5, flash-plugin i386, mozilla-plugin-config bongoman Using Fedora 21 30th July 2009 02:58 AM
Opera and Flash-Plugin on Fedora x86_64 Keldorn Using Fedora 0 6th July 2008 05:40 PM
Woohooo Flash + Plugin For X86_64 In A While !!! Knudson Using Fedora 1 16th January 2006 11:32 AM
Current GMT-time: 12:06 (Saturday, 21-10-2017)
