Old 26th July 2017, 01:02 AM
pjsf1 Offline
linuxfedorachrome
Re: After Upgrade to F26: Always asked for root password on login (additionally)
Disabling Blueman's networking plugin and KillSwitch plugin seems to work for me.
Old 26th July 2017, 09:00 AM
antikythera Offline
there's a bug open about this blueman networkmanager plugin issue. However, I'm not sure of the maintenance status of blueman though as it has been orphaned a couple of times now. blueberry seems to work okay for connections with my own hardware but I know that won't be the case for every usage scenario.
Again, if you find issues with blueberry, they need reporting so they can be fixed.
Old 27th July 2017, 03:23 PM
dcrdev Offline
windows_7chrome
I was tempted to do this given that the bug report isn't getting any attention (not that I've ever seen a bug get any attention on bugzilla) and this is actually delaying the startup of the compositor I'm using in XFCE, however the pulseaudio bluetooth module has a dependency on blueman; it's something I actually use frequently.
Really quite shocked that this was F26 got released with this bug - not because it's huge, but because it's visible on boot and affects everyone using bluetooth.
Old 28th July 2017, 02:28 PM
dcrdev Offline
linuxfedorachrome
To follow up in this it seems that the pulse bluetooth module can work with blueman or blueberry, it's just a case of removing blueman AFTER installing blueberry; or just reinstalling the module ofcourse.
Does F26 use blueberry by default then, meaning we're just affected because we upgraded?
Old 28th July 2017, 04:02 PM
antikythera Offline
I can only confirm blueberry has replaced blueman in MATE-Compiz spin. I would think the other GTK based desktops have done the same as blueman has been orphaned so many times recently.
also yes, it's blueman being left over from previous builds causing the issue with upgraded systems
Old 6th August 2017, 03:55 PM
Breezeman Offline
macossafari
I had the same issue. I removed blue man and the 2 additional prompts went away. I use Bluetooth upon occasion however I'll look for a work around once I have more time. For now all is good and the annoyance of the additional prompts during reboots is gone. Thanks to lose who have provided commentary in this. It took some time to find the thread on this specific issue.
Old 23rd September 2017, 11:19 AM
voleg Offline
Assuming you've already added yourself to "wheel" group.
Drop this content to file /etc/polkit-1/rules.d/81-blueman.rules :
[CODE]
polkit.addRule(function(action, subject) {
if (action.id == "org.blueman.rfkill.setstate" && subject.local && subject.active && subject.isInGroup("wheel")) {
return polkit.Result.YES;
if (action.id == "org.blueman.network.setup" && subject.local && subject.active && subject.isInGroup("wheel")) {
[CODE]
This should be enough to relax polkit.
Old 24th September 2017, 05:11 AM
Doug G Offline
Thanks voleg, I just added the rules on this laptop, rebooted, and the extra two auth steps vanished
Do you know where to find the documentation explaining how these rules work? Thx,
Doug G
Old 24th September 2017, 05:38 AM
voleg Offline
unknownfirefox
Read about polkit, policykit, pkaction. Discovered as handy tool !
additionally , asked , f26 , login , password , root , upgrade
root login via ssh fedora 12 password authentication mattmarion Security and Privacy 3 27th January 2010 07:23 PM
No more asked for root password fabbo Using Fedora 4 15th November 2007 11:33 PM
mistyped root password now cannot login bluejuice Using Fedora 1 25th May 2005 11:23 AM
Current GMT-time: 03:43 (Wednesday, 18-10-2017)
