Old 13th February 2017, 07:46 PM
dibaryon Offline
Re: cernlib
Does this work on Fedora 23?? Can anyone help me out?
Old 14th February 2017, 05:12 PM
bruno.taglienti Offline
Re: cernlib
I tried the same recompilation in a VM for Fedora 23, but it fails and I was not able to understand the errors
Bruno Taglienti
Old 15th February 2017, 03:43 PM
dibaryon Offline
Re: cernlib
I did kind of a temporary trick. I was using Fedora 20 and all of my programs were compatible. I usually use ROOT and write C++ and Fortran codes. So, what I did as an administrator was saved the files in the exact locations they were on a different machine which has Fedora 20 and updated the configurations using "ldconfig". Except for a few, all the libraries got updated and I could run my programs without problem.
I know this is not a great way to solve the problem but could be used as a temporary around-the-problem-solution.
I look forward to other robust ways to deal with this.
Cheers!
Last edited by dibaryon; 15th February 2017 at 03:45 PM. Reason: Included more information
Old 10th August 2017, 08:03 PM
John Marraffino Offline
Re: cernlib
Has anybody successfully installed the cernlib kit under Fedora 26? I tried it following the lead in this thread for installation under Fedora 25. The build staggered its way to the end but a lot of the tests failed.
cernlib, fedora21
cernlib installation problem wellatiger Using Fedora 7 14th August 2012 01:00 PM
Current GMT-time: 23:04 (Wednesday, 23-08-2017)
