Old 12th October 2017, 12:31 PM
topiwala Online
Re: I like to know meaning of groups in Linux
i would prefer firejail over using groups etc.
Old 12th October 2017, 01:18 PM
flyingdutchman Offline
Paranoid much? In my experience WINE viruses are not really a problem.
Have fun!
http://www.aeronetworks.ca
Old 12th October 2017, 04:59 PM
User808 Offline
linuxsafari
@topiwala
2 problem with firejail:
1) not available neither in Fedora repositories nor in RPMFusion repositories. Only in coper. Why such great application not available, I do not understand !
2) I do not use Wine only for games. I use it for PDF editor & irfanview. So, does isolation (sandboxing) such applications by firejail allow them to be still productive ? If irfanview isolated by firejail, then does it will be still able to handle & edit images ?
@flyingdutchman
I'm very unlucky man in my life, & I expect that bad things that are rare & uncomon to face me as rain of stones over my head ! This is what called bad luck ! I'm of that type ...
Fedora 26 X64 bit Cinnamon edition on Lenovo ThinkPad e550 with Intel core i7 5500 CPU @ 2.40 GH X 2, RAM = 8 GB, HHD = 1 TB, Hybrid VGA (Intel Corporation HD Graphic 5500 + Radeon R7 M265 2GB)
Old 12th October 2017, 06:15 PM
topiwala Online
i agree not having it in official repos is a problem but i use this solution
a- i compile. It is easy as compared to other programs
b- to keep me updated i use RSS feed. Firejail page has Atom feed.
As for second problem i haven't used those programs.
Now a days i do not even install wine.
Last edited by topiwala; 12th October 2017 at 06:16 PM. Reason: Atom not RSS feed. added
Old 12th October 2017, 06:56 PM
User808 Offline
linuxsafari
WineHQ & Anbox are 2 great tools ! Wine make you able to use Windows applictions on Linux. If you observing change log of wine, you will see that versions 2+ started to add very important features, so that version 3 will be very good. I suspect that version 4 at 2019 will be excellent.
Regarding anbox:
https://anbox.io
it is still alpha. It enable you to run Android applications on Linux in exetra ordinary way ! It is secure by default !
No other OS like Linux in it's elasticity !
Old 12th October 2017, 07:16 PM
topiwala Online
My experience with wine was "difficult".
I use virtual machine if need like for scanning or android SDK. I will look into anbox.
For most i am exclusively linux user.
Old 12th October 2017, 07:53 PM
User808 Offline
Regarding Anbox, please beware that currently there is something you should download & install manually to install Anbox on Fedora - read their forum or bug, I do not remember exactly .... Test it on Debian is better, as I think .... It is still ALPHA !
I'm like you, mostly Linuxer, now ! But game ! There are very nice windows games not available on Linux ......
Old 12th October 2017, 10:12 PM
lsatenstein Offline
Hi User808
Everyone has access to the su command.
Only a wreckless administrator or an adminstrator with poor linux/security knowledge will give that user the root password.
Once that user is given the root password, he can edit /etc/group and add his login to the wheel group.
That is why we allow sudo. And yes, with sudo you do not have to give total system access . You can even manage printing, file allocation, and commands that you want to remain privileged.
Old 12th October 2017, 11:13 PM
User808 Offline
linuxsafari
Originally Posted by lsatenstein View Post
Hi User808
This is bad ! FreeBSD do not allow this. I think every new user added should be by defsult has no sudo, no su powers + unable to gain root from within any GUI including Gnome software.
Old 12th October 2017, 11:46 PM
sidebrnz's Avatar
sidebrnz Offline
Why is it bad? Just having access to su doesn't give you access to root because you still need to know root's password. And, although you can also use su to become some other user, you still need that user's password. Also, in Fedora (and I think Ubuntu) only the first user you create is added to wheel by default. If you don't want anybody else to have access to root, don't add them to wheel and don't tell them the root password.
Registered Linux user #470359 and permanently recovered BOFH.
Any advice in this post is worth exactly what you paid for it.
Old 13th October 2017, 05:44 AM
User808 Offline
linuxsafari
What it will be the case if Wine dependent virus has build in tool for spantanous password generator & thus will trying to crack su password ? This is what I concerned about.
Let we return to topic of this thread. Do any one used "nobody" group & no more about what happened for user added to this group ?
Old 13th October 2017, 06:24 AM
sidebrnz's Avatar
sidebrnz Offline
True, but why bother? Once you have the root password, you don't need sudo. As an example, the only reason I have it installed on my computer is that there are packages that need it, because I certainly don't. Whenever I need root, I use su.
groups , linux , meaning
Groups and Environment Groups djl47 Using Fedora 0 10th December 2015 09:32 AM
Yahoo Groups dedicated to Linux tech291083 Wibble 3 8th April 2013 02:50 PM
is the meaning of bogomips different between 32 bit and 64 bit timcoote Using Fedora 0 22nd April 2009 02:53 PM
fc9 yum failed, who can tell me what't the meaning? comain Using Fedora 5 19th May 2008 01:46 AM
what is meaning of sha1sum? kalpana Installation, Upgrades and Live Media 10 13th July 2005 01:17 PM
Current GMT-time: 15:39 (Sunday, 22-10-2017)
