Old 12th October 2017, 10:01 PM
lsatenstein Offline
Re: Is there a way to add alias's to sudo ?
Did you carefully review the alias for sudo.
sudo with one space in the alias for sudo should do the job.
Old 12th October 2017, 10:27 PM
dswaner Offline
Sorry for the confusion, but it does work if you add the "shopt -s expand_aliases"
to root's .bash_profile, not the user's. That is, "sudo -i ll" works as expected.
Also, regarding
I haven't tried that technique, but I'm certain that it works, since it is working for a number of
contributors to this thread. I'll stick with the "shopt -s expand_aliases" technique.
add , alias , sudo
[SOLVED] sudo NOPASSWD to .bashrc alias? Bazu135 Security and Privacy 6 3rd September 2011 09:31 AM
Cannot open /var/db/sudo after sudo package upgrade Replicant10000 Security and Privacy 1 16th September 2010 01:25 PM
How to Change Firefox Alias or any Alias? FergatROn Using Fedora 1 3rd June 2008 09:18 PM
alias help madjac Using Fedora 0 5th May 2007 09:44 PM
sudo question (host alias) arc2v Using Fedora 2 23rd June 2005 01:37 PM
Current GMT-time: 15:41 (Sunday, 22-10-2017)
