Old 28th February 2016, 01:21 PM
boycottsystemd Offline
Re: Bootloader has not verified loaded image. System is compromised. Halting.
Log from rebooting Fedora:
Feb 28 10:47:34 localhost systemd: Unmounted /run/user/1000.
Feb 28 10:47:34 localhost systemd: boot-efi.mount: Mount process exited, code=exited status=32
Feb 28 10:47:34 localhost systemd: Unmounted /boot/efi.
Feb 28 10:47:34 localhost systemd: boot-efi.mount: Unit entered failed state.
Feb 28 10:47:34 localhost systemd: Unmounting /boot...
Feb 28 10:47:34 localhost systemd: Stopping LVM2 metadata daemon...
Feb 28 10:47:34 localhost systemd: Stopped LVM2 metadata daemon.
Is it OK ?
Old 3rd April 2016, 12:42 PM
...localhost systemd: boot-efi.mount: Unit entered failed state.
has disappeared but other problems still persists.
Old 11th July 2016, 02:45 PM
I was wondering whether upgrade to F24 could fix these problems but according to some posts from kernel-4.6.3-300.fc24 doesn't boot it could go even worse. So would it be better to wait for F25 ?
Old 12th July 2016, 04:40 AM
nsnbm's Avatar
nsnbm Offline
That kernel-4.6.3 is an upgraded one from the release one which is 4.5.5-300, so if you install from the f24 release iso you would get the earlier one which doesn't seem to have had some of the problems of later ones.
Old 30th July 2016, 10:14 AM
Thank you, but I'm trying to avoid installer because it can heavily damage data if installation freeze.
Old 29th November 2016, 05:06 PM
I tried mount partition with Ubuntu before updating grub as recomended here: http://www.forums.fedoraforum.org/sh...03&postcount=7
and
grub2-mkconfig -o /boot/efi/EFI/fedora/grub.cfg
Ubuntu has been added to boot menu but Ubuntu still can't boot:
error: can't find command `linux'
error: can't find command `initrd'
Old 23rd January 2017, 10:14 AM
After upgrade to F24:
I ran
sudo grub2-mkconfig -o /boot/efi/EFI/fedora/grub.cfg
But Ubuntu still can't boot:
error: /boot/vmlinuz-4.4.0-54-generic.efi.signed has invalid signature
error: you need to load the kernel first
Press any key to continue...
Does anyone know please how to fix it ?
Old 5th October 2017, 01:28 PM
SOLVED after more than 3 years:
upgrade F24 to F25
and
sudo dnf reinstall grub2-efi grub2-efi-modules shim
Old 7th October 2017, 06:31 AM
nsnbm's Avatar
nsnbm Offline
Dunno why that didn't work before as mentioned in your post #9, and why it took an upgraded fedora to work, but I'm glad that it has.
Old 12th October 2017, 09:43 AM
I don't know what happened. I hope current correct state will last for a long time
It's irony of fate that similar problem has appeared on another machine: https://forums.fedoraforum.org/showthread.php?t=315689
bootloader , compromised , halting , image , loaded , verified
boot loader has not verified loaded image noraml Hardware & Laptops 4 8th June 2014 01:51 PM
System compromised ? thms0 Security and Privacy 2 29th October 2012 02:04 PM
Shutdown fails at 'Halting System' on F8 gregma Using Fedora 4 2nd March 2008 01:57 AM
system compromised? 84NITRAM Using Fedora 2 24th December 2006 03:14 AM
BIG problem... System halting. Owy Hardware & Laptops 2 16th March 2006 09:57 AM
Current GMT-time: 08:19 (Sunday, 22-10-2017)
