Old 21st July 2017, 07:45 PM
lavie Offline
windows_98_nt_2000chrome
Re: xrdp " Listening socket is in wrong state, terminating listener"
Some more info:
This could be due to a change in the MS mstc client itself.
I just installed a Fedora 25 from original media, and installed the old version of xrdp (9.0.6).
I got the same problem.
Old 22nd July 2017, 01:00 AM
ToddAndMargo Offline
To whom do I complain? Where can I register a bug?
https://bugzilla.redhat.com
https://github.com/neutrinolabs/xrdp/issues/832
Old 22nd July 2017, 01:07 AM
The broken clipboard will cause you to crash as well. For details, see:
https://github.com/neutrinolabs/xrdp/issues/469
It is a total pain in the neck (not my "exact" word).
Old 22nd July 2017, 10:03 AM
lavie Offline
Not your exact word? You meant to say "ABSOULTE pain in the neck"???
Old 22nd July 2017, 04:37 PM
armonica Offline
I filed a bug report - Bug 1473938
fedora 25 , gnome , vnc , windows 7 , xrdp
[SOLVED] Milter-Greylist failing to create socket / "unsafe" PolywogSys Guides & Solutions (Not For Questions) 0 22nd February 2012 02:43 AM
differences between "struct sock" and "struct socket" ahm_irf Programming & Packaging 0 30th March 2009 05:24 AM
System Hangs Gives "kernel: Bad page state in process 'pdflush'" - Any thoughts? Jay Rhine Using Fedora 0 26th September 2007 05:51 PM
are new solid state drives equivalent to "swapon /dev/sdc1" icthy Using Fedora 8 4th January 2007 04:49 PM
Error:visibility arg must be one of "default", "hidden", "protected" or "internal" wangfeng Using Fedora 0 23rd May 2005 04:59 AM
Current GMT-time: 20:53 (Sunday, 22-10-2017)
