Go Back   FedoraForum.org > Fedora 25/26 > Using Fedora
Using Fedora General support for current versions. Ask questions about Fedora that do not belong in any other forum.
Old 6th April 2017, 10:36 AM
nobody Offline
windows_98_nt_2000chrome
Arrow Re: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
Originally Posted by foottuns View Post
Don't seem to see any Xorg logs here.
[user@localhost c-examples]$ cd ~
[user@localhost ~]$ pwd
/home/user
[user@localhost ~]$ whoami
user
[user@localhost ~]$ find . -name Xorg*
find: ‘./.config/htop’: Permission denied
./.local/share/xorg/Xorg.0.log
[user@localhost ~]$ env | grep XDG_SESSION_TYPE
XDG_SESSION_TYPE=x11
[user@localhost ~]$ echo $XDG_SESSION_TYPE
x11
[user@localhost ~]$
_nobody_
I am nobody, and nobody is perfect, therefore I am perfect!
Old 6th April 2017, 10:45 AM
foottuns Offline
linuxfedorachrome
This bug is listed here too -
https://bugs.freedesktop.org/show_bug.cgi?id=100516
A fix is scheduled for version 4.12 - Now it is all about waiting....
the v4.12 kernel predictions: merge window closes on Sunday, 2017-05-21 and release on Sunday, 2017-07-09
Old 6th April 2017, 10:51 AM
Ben.Hahlen Offline
linuxfedorachrome
I am using Fedora 25 with Gnome on Wayland.
I don't have a Xorg.log, so that won't really help :-)
Just out of curiosity, how many monitors do you use?
I wonder if this is related, I am using 2 extra monitors.
I am running on one monitor, my laptop screen.
Also, just seeing that the bug I found (link) has been marked as CLOSED/FIXED.
The only thing that I can't find is WHERE it has been fixed and if we can expect that fix at some point?
---------- Post added at 11:51 AM ---------- Previous post was at 11:46 AM ----------
It happen 6 days ago.
Queued for 4.12... So 4.11 is also suffering from this, so we're basically screwed for a bit, unless someone backports it. Or something.
http://www.benweb.eu
Old 6th April 2017, 12:24 PM
foottuns Offline
linuxfedorachrome
I don't believe we would be getting the update soon, yes you are right, we are screwed for a bit..until July ...
Faster would be if we recompile the kernel ourself ...
bug , dereference , handle , kernel , null , pointer , unable
kernel: BUG: unable to handle kernel NULL pointer dereference cyborg Using Fedora 2 25th March 2015 11:40 PM
FC12: Null pointer dereference james.primrose Using Fedora 3 4th December 2009 02:26 AM
Error installing F12 - unable to handle kernel null pointer dereference daviddoria Installation, Upgrades and Live Media 2 25th November 2009 04:46 PM
kernel: Unable to handle kernel NULL pointer dereference at virtual address 0000000c pmzandbergen Using Fedora 15 27th September 2006 03:41 PM
Unable to handle kernel NULL pointer dereference at virtual address 0000019c rschwarz Using Fedora 2 24th February 2006 12:48 AM
Current GMT-time: 11:44 (Sunday, 22-10-2017)
