Sound configuration - raise volume
    Kaotik2003 Guest
    Is there anyway to raise the volume of sound in general? To listen to system messages and xmms or mplayer, I have to put my volume at maximum.
    If anyone knows please tell me how to do it.
    Thanks for always helping.
    Crux Guest
    Raise the 'input' levels in Kmixer
    Dec 2004
    Canada
    30
    9,221
    in a terminal type
    alsamixer
    esc saves
    Firewing1
    [+] My open source software and blog
    [+] Some of my howtos: (for full list, click here)
    Kaotik2003 Guest
    Done. Thanks guys.
    Firewing you are always there. Thanks mate.
    Dec 2004
    Canada
    30
    9,221
    no problem
    I've noticed sometime sa "esc" won't save on reboot, to completely save alsamixer changes (as root,) type
    /usr/sbin/alsactl store
    Firewing1
  1. Raise window only when titlebar is clicked?
    By dan_seddon in forum Using Fedora
    Last Post: 12th October 2008, 06:13 PM
  2. gnome-volume-properties configuration file
    By mr reuz in forum Using Fedora
    Last Post: 17th September 2006, 06:31 AM
  3. Replies: 8
    Last Post: 15th January 2005, 12:47 AM
  4. Metacity: click thru raise
    By leed in forum Using Fedora
    Last Post: 14th July 2004, 04:48 AM
  5. raise refresh rate in fedora core 2
    By crisdawg in forum Hardware
    Last Post: 24th June 2004, 11:53 AM
