6th December 2005, 05:54 AM
xmms cddb problem
I've seen this problem posted but not answered. In xmms the cddb function isn't working for me. xmms functions well otherwise in all respects. Grip's cddb function does work fine by the way.
The xmms cddb network debug window shows a successful connection to freedb.org with a "got level 6". Then..." sending query-command discID e70q6f10"...
but finally the message ..."query response: 500 command syntax error"...
Is there a way to fix this??? As far as I can tell things are configured properly on my end, I have the CD Audio plugin 1.2.10 and configured it for cddb with freedb.org. Tried with various CD's always the same. Grip's cddb lookup works well, xmms doesn't. Any thoughts out there? Thank you.
5th February 2006, 10:10 PM
Same problem here. It is farily new. Worked fine last week.
By armandocl in forum Using Fedora
Last Post: 10th September 2007, 08:21 AM
By swamp in forum Using Fedora
Last Post: 4th August 2007, 06:33 PM
By Archangel0183 in forum Using Fedora
Last Post: 9th February 2007, 02:24 AM
By sklm in forum Using Fedora
Last Post: 28th June 2006, 11:24 PM
By driftwood in forum Using Fedora
Last Post: 22nd February 2006, 02:47 AM
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
[[template footer(Guest)]]
