    May 2005
    128
    poor sound quality
    I have a hercules game theater xp and am using the alsa drivers for it in FC3 but I get horible sound quality. It is very high in treble and there is no base plus lots of distortion. Any ideas how to fix the probleam. The strange thing is it sounds ok when listening to everything using headphones but when I switch to my surround sound speakers it sound awful and I know the speakers aren't blown because they work fine in winblows!
    May 2005
    Abq, NM
    40
    1,158
    i had the same problem with a much different sound card but the solution may be the same or at least worth a shot.
    run alsamixer from a terminal as root and mute the headphone control (and associated headphone volumes if it allows) and unmute the others (PCM, Line, etc). I also had to mute a couple of 3D controller options. May take a bit of messing around with... it took a while for me to get mine sounding good.
    Hope that helps,
    Joseph
    I am root. If you see me laughing you better have a backup.
    May 2005
    128
    I'll give it a try. Thanks for the suggestions
  1. HP Pav Dv6000, poor sound quality
    By Squire_James in forum Hardware & Laptops
    Last Post: 14th March 2008, 10:39 AM
  2. Poor sound quality with RealPlayer
    By ar-jar in forum Using Fedora
    Last Post: 8th March 2007, 05:56 PM
  3. got soundcard working...poor quality sound
    By rootloser in forum Hardware & Laptops
    Last Post: 6th October 2005, 07:22 AM
  4. Poor quality sound + alsamixer not working correctly
    By Vinneh in forum Fedora Core 4 Test
    Last Post: 5th May 2005, 01:33 AM
  5. Grip: poor mp3/ogg quality
    By pmelab in forum Using Fedora
    Last Post: 12th November 2004, 12:02 AM
