gdesklets problem
    jackuto Guest
    gdesklets problem
    hi, i've just found out when i'm running gdesklets ./configure command, i found this output:
    configure: error: Library requirements (pygtk-2.0 >= 2.4.0 pyorbit-2 >= 2.0.1 gnome-python-2.0 >= 2.6.0) not met; consider adjusting the PKG_CONFIG_PATH environment variable if your libraries are in a nonstandard prefix so pkg-config can find them.
    what's wrong with it? does the dependencies not meet?
    i've checked the py thang as follow, what am i missing?
    {######@localhost gDesklets-0.34.1]$ rpm -qa | grep pygtk
    pygtk2-2.4.0-1
    pygtk2-libglade-2.4.0-1
    pygtk2-devel-2.4.0-1
    [j######@localhost gDesklets-0.34.1]$ rpm -qa | grep pyorbit
    pyorbit-2.0.1-1
    [j######@localhost gDesklets-0.34.1]$ rpm -qa | grep gnome-python
    gnome-python2-bonobo-2.6.0-3
    gnome-python2-gtkhtml2-2.6.0-3
    gnome-python2-canvas-2.6.0-3
    gnome-python2-gconf-2.6.0-3
    gnome-python2-2.6.0-3
    osxcube Guest
    I had the same problem.
    My solution: > sudo yum install pyorbit-devel
    jackuto Guest
    i've install it with yum instead, it doesn't appear to be have dependencies problem like i install it through tar. right now run it in command line like below and found this output:
    gdesklets start
    Starting gdesklets-daemon...
    Cannot establish connection to daemon: timeout!
    again what am i missing here?
    artur Guest
    [gdesklets start
    Cannot establish connection to daemon: timeout!]
    Yeah same here... Would be glad to know a fix.
    jackuto Guest
    can somebuddy tell me how to remedy the situation here? thanks very much
  1. gdesklets problem
    By Ric@rdo in forum Using Fedora
    Last Post: 18th June 2008, 11:09 PM
  2. gdesklets problem
    By ToolNIN420 in forum Using Fedora
    Last Post: 20th September 2006, 04:21 AM
  3. gdesklets problem, help please
    By the_phet in forum Using Fedora
    Last Post: 14th July 2006, 11:49 PM
  4. Problem with gdesklets
    By Benz in forum Using Fedora
    Last Post: 23rd August 2005, 10:31 PM
  5. Problem with gDesklets
    By DXT in forum Using Fedora
    Last Post: 18th November 2004, 10:41 AM
