modprobe: FATAL: Error running install command for sound_slot_1
    GrahamB Guest
    Hi All!
    I am having problems getting sound out of my SB Live. This error appears now. Can you help me solve it?
    [root@merlin root]# cat /var/log/messages | grep modprobe
    Mar 4 20:22:12 merlin modprobe: FATAL: Error running install command for sound_slot_1
    Mar 4 20:22:12 merlin modprobe: FATAL: Error running install command for sound_slot_2
    Mar 4 20:22:12 merlin modprobe: FATAL: Error running install command for sound_slot_3
    I get the error on startup and by running /etc/rc.d/init.d/alsasound.
    Thanks
    GrahamB
    PS: This is what my /etc/modprobe.conf looks like:
    # Ethernet
    alias eth0 8139too
    # USB
    alias usb-controller uhci-hcd
    # From the alsa.org site, for emu10k1:
    # ALSA portion
    alias char-major-116 snd
    alias snd-card-0 snd-emu10k1
    # module options should go here
    # options snd-emu10k1 mpu_port=0x330 index=0
    # options snd-rawmidi midi_map=0
    # OSS/Free portion
    alias char-major-14 soundcore
    # card 1
    alias sound-service-0-0 snd-mixer-oss
    alias sound-service-0-1 snd-seq-oss
    alias sound-service-0-3 snd-pcm-oss
    alias sound-service-0-8 snd-seq-oss
    alias sound-service-0-12 snd-pcm-oss
    # SB Live install/remove coding
    install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 && /usr/sbin/alsactl restore >/dev/null 2>&1 || :
    remove snd-emu10k1 { /usr/sbin/alsactl store >/dev/null 2>&1 || : ; }; /sbin/modprobe -r --ignore-remove snd-emu10k1
    # post-install snd-card-0 /usr/sbin/alsactl restore >/dev/null 2>&1 || :
    # pre-remove snd-card-0 /usr/sbin/alsactl store >/dev/null 2>&1 || :
    # --- BEGIN: Generated by ALSACONF, do not edit. ---
    # --- ALSACONF verion 1.0.8 ---
    alias sound-slot-0 snd-emu10k1
    # --- END: Generated by ALSACONF, do not edit. ---
    Feb 2005
    50
    60
    What kind of SB Live! is it? I have a SB Live! 24-bit but it doesn't use the emu10k1 drivers like the rest of the Live! family does. I haven't really had much success getting it to work either. I found a couple of posts on here, but none of them fixed my problem.
    On a related note: I keep seeing references to the "modprobe" command, but when I type in "modprobe" in a command line, I get a "command not found" error. Am I missing something here?
    System Specs:
    Compaq 2195us
    Fedora Core 3
    • Athlon XP-M 2500+
    • 512 MB RAM
    • Radeon IGP 320M
    • 40 GB Hard Drive
    • Broadcom 802.11g Wireless
    • ~2.5 Hrs Battery Per Charge
    Feb 2004
    49
    8,255
    if you pay attention to his post you will see this line:
    which tells how the command is being issue.
    Now about your sound problem were you able to test your sound after the installation? I am not sure if this will help you: http://www.euronet.nl/~mailme/old_page/
    GrahamB Guest
    Hi Unkemptwolf!
    I believe that my sound card is SB Live 5.1. It appears to belong to the 24 bit familly.
    This from the Creative Labs product information:
    The Sound Blaster® Live!™ brings cinema-quality sound to your movies, music, and games with digital 5.1 clarity. Driven by the powerful EMU10K1™ Digital Signal Processor, you will experience the highest quality sound reproduction with real-time audio and effects. The Sound Blaster Live! includes Creative PlayCenter™ with a full 320kbps encoder and 9X MP3 acceleration, etc...............
    Regards
    GrahamB
  1. wine fatal error (F9 x86_64) running PokerStars
    By mwette in forum Gamers' Lounge
    Last Post: 2nd October 2008, 04:27 AM
  2. modprobe ndiswrapper : FATAL error
    By abhiusms in forum Servers & Networking
    Last Post: 27th May 2008, 09:59 AM
  3. error running install command for sound_slot 1
    By laktech in forum Using Fedora
    Last Post: 10th February 2005, 09:10 AM
