Lenovo Thinkbook no sound over speakers with Fedora 33
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 15 of 47
    Jan 2021
    20
    Laptop: Lenovo Thinkpad 13s Gen 2 Intel Tiger Lake (https://psref.lenovo.com/syspool/Sys...2_ITL_Spec.PDF)
    OS: Fedora 33 (KDE)
    The laptop came with Windows 10 pre-installed and the sound does output from the speakers on Win. I swapped out the SSD to try Fedora 33 and it was able to install without issue when I chose automatic partitioning. I noticed there was no sound playback. I plugged in headphones via the 3.5mm jack and sound outputs just fine to the headphones.
    In the audio control the output devices available are:
    Tiger Lake audio control Speaker + Headphone - this has a port drop down with 2 values: a) Speaker b) Headphone. Naturally I had it set to speaker and when I plug in headphones it is automatically set to headphones.
    HDMI 1
    HDMI 2
    HDMI 3
    The laptop has a dedicated HDMI port as well as 2 display outputs via a Thunderbolt port, so I guess that's what is 2, 3 and 4.
    I followed this post https://www.reddit.com/r/Fedora/comm...9310_no_audio/ and tried adding snd-intel-dspcfg.dsp_driver=1 to GRUB_CMDLINE_LINUX. What that is was make the output device list contain only "Analog Speakers" and audio did not output from the speakers. So I reverted that change.
    Next I tried updating the sof-firmware package, which as far as I could tell is alsa-sof-firmware in Fedora land. Fedora 33 came with 1.6-2 and rawhide has 1.6-4 so I upgraded to that. Didn't change a thing for me.
    Does anyone have suggestions on other things I can try to get sound output from the speakers?
    Feb 2008
    Sydney Australia
    66
    2,669
    Re: Lenovo Thinkbook no sound over speakers with Fedora 33
    If you don't already have it install PulseAudio Volume Control, dnf install pavucontrol. Then check the output devices and confirm that the correct device is selected and the speakers aren't muted.
    Jan 2021
    20
    Installed Pulse volume control - nothing amiss there.
    Feb 2008
    Sydney Australia
    66
    2,669
    That does look okay presuming that the device shown is the one selected on the Configuration tab. The volume is a bit low, at that point my Thinkpad barely makes a sound.
    Try playing some music and see that there is activity shown on the bar below the volume bar.
    Another option is to look at alsamixer on a command line and check that nothing is muted there. There used to be an issue on some sound cards with auto-mute but I haven't heard of that for a long time. It should be shown in alsamixer after pressing F6 and selecting the sound card.
    Jan 2021
    20
    Quote Originally Posted by ozjd
    Yep I moved that volume slider all the way from 0 to max. Made no difference. No sound on the speakers. With headphones plugged in I get sound, albeit with hissing and crackling that is more pronounced when using the touchpad.
    Both when the headphones are connected as well as when they are disconnected there is activity in the bar below the volume. Which shows it is registering sound being produced on the system.
    Yup did this as well, there was nothing amiss there either as far as I could tell.
    Feb 2008
    Sydney Australia
    66
    2,669
    Is the system fully updated? I did some searching and found a comment that an update to alsa-sof-firmware solved some issues with Tiger Lake sound.
    Jan 2021
    20
    Yup, the I have the latest alsa-sof-firmware for 33. And I tried a package bump from the rawhide repo too.
    Dec 2017
    Reboot
    874
    22 Post(s)
    I would suggest poking into the logs (applications>logs) and see what shows up there or direct alsa logs for debugging https://www.alsa-project.org/wiki/Help_To_Debug
    There's different pieces that affect sound and can all cause various changes:
    Sometimes not obvious, might be physical sound controls (try messing with those, maybe it will do something): https://support.lenovo.com/us/en/sol...ssues-thinkpad
    Kernel
    Alsa & pulseaudio
    Bios
    The alsa config file could in theory help here but it might not if its very broken.
    So for example, you could try removing pulesaudio and try using alsa directly, updating the bios, using an older kernel, using a vanilla kernel, so on.
    You could try $ alsamixer
    Or testing the mic to see if its not just sound output with arecord.
    Lots of stuff.
    Feb 2008
    Sydney Australia
    66
    2,669
    Checking logs is a good idea but I wouldn't recommend removing PulseAudio as it is used by everything. It is likely to cause more problems than it fixes.
    I'm guessing you have tried audio from more than one application although that rarely causes a problem these days thanks to PA.
    Plasma appears to just use the PA settings too so there is unlikely to be anything in there that is causing the issue.
    Other than that I don't know what else to suggest as you have done everything that solves the problem for most people.
    Dec 2017
    Reboot
    874
    22 Post(s)
    Ymmv on that. For me it was only Steam and no big of a deal when I tested that. Its also listed with Fedora sound troubleshooting https://fedoraproject.org/wiki/How_t...sound_problems so take it as you will. Depends what you have installed.
    Its only meant to test, not cause problems. Pulseaudio can be reinstalled
    Based on what you say, logs and debugging might be the only good way to go now with this as it doesn't sound normal-ish at all.
    Jan 2021
    20
    Re-installed pulseaudio - didn't help.
    This looks relevant from the logs:
    Jan 03 22:15:51 localhost.localdomain pipewire[1661]: [E][000000048.968917][core.c:71 core_event_error()] core 0x55dd14ea4110: proxy 0x55dd14eddbd0 id:4: bound:-1 seq:4 res:-2 (No such file or directory) msg:"can't create device: No such file or directory"
    Jan 03 22:15:51 localhost.localdomain pipewire[1661]: [E][000000048.968927][media-session.c:1971 core_error()] error id:4 seq:4 res:-2 (No such file or directory): can't create device: No such file or directory
    Jan 03 22:15:51 localhost.localdomain pipewire[1659]: [E][000000048.969829][alsa-pcm.c:33 spa_alsa_open()] 'hw:sofhdadsp,5': playback open failed: Device or resource busy
    Jan 03 22:15:51 localhost.localdomain pipewire[1659]: [W][000000048.969834][adapter.c:175 find_format()] adapter 0x55ac1e726bc0: can't get format: Device or resource busy
    Jan 03 22:15:51 localhost.localdomain pipewire[1659]: [E][000000048.969837][module-adapter.c:229 create_object()] can't create node: Device or resource busy
    Jan 03 22:15:51 localhost.localdomain pipewire[1661]: [E][000000048.981999][core.c:71 core_event_error()] core 0x55dd14ea4110: proxy 0x55dd14f0e6e0 id:43: bound:-1 seq:141 res:-16 (Device or resource busy) msg:"can't create node: Device or resource busy"
    Jan 03 22:15:51 localhost.localdomain pipewire[1661]: [E][000000048.982010][media-session.c:1971 core_error()] error id:43 seq:141 res:-16 (Device or resource busy): can't create node: Device or resource busy
    Jan 03 22:15:51 localhost.localdomain pipewire[1659]: [E][000000048.982129][alsa-pcm.c:33 spa_alsa_open()] 'hw:sofhdadsp,4': playback open failed: Device or resource busy
    Jan 03 22:15:51 localhost.localdomain pipewire[1659]: [E][000000048.982166][alsa-pcm.c:33 spa_alsa_open()] 'hw:sofhdadsp,3': playback open failed: Device or resource busy
    Jan 03 22:15:51 localhost.localdomain pipewire[1659]: [E][000000048.982197][alsa-pcm.c:33 spa_alsa_open()] 'hw:sofhdadsp': playback open failed: Device or resource busy
    Jan 03 22:15:51 localhost.localdomain pipewire[1661]: [E][000000048.982613][core.c:71 core_event_error()] core 0x55dd14ea4110: proxy 0x55dd14f0f400 id:44: bound:41 seq:156 res:-16 (Device or resource busy) msg:"enum params id:3 (Spa:Enum:ParamId:EnumFormat) failed"
    Jul 2017
    wallpapers
    1,960
    52 Post(s)
    Hello.
    If you have installed all the codecs to support the audio/video, Then the next option will be to change the usb port on the machine.
    I had that issue last night on machine that I have installed for Friend of my - that solve the issue.
    Just so you will know...Yesterday there was change in the pulseaudio volume control software.
    so...before you fire up the system,just change the USB Port then fire up the system.
    That will fix the issue for you.
    FFedora
    fedoraforum.org-Wallpapers
    https://forums.fedoraforum.org/group.php?discussionid=304&do=discuss
    Jan 2021
    20
    Quote Originally Posted by FFedora
    Hello.
    I don't quite understand what you mean by "just change the USB Port then fire up the system". No external port is in use in my scenario. Unless you count the power delivery from the USB C Thunderbolt port.
    Jul 2017
    wallpapers
    1,960
    52 Post(s)
    well I see the image that you have post here from -Pulse volume control.
    And I see that the Volume is click and close in 3 of the options there (just the last one is working and not clicked).
    Try to click on the 3 options of the HDMI , but change first to all output in the bottom.
    FFedora
    Jan 2021
    20
    Thanks but that didn't work.
  1. No sound on Lenovo ThinkBook 13s
    By dephinera in forum Hardware
    Last Post: 16th March 2020, 04:52 PM
  2. Replies: 0
    Last Post: 19th October 2013, 06:34 PM
  3. Fedora 16 - speakers work, headphones no sound.
    By appaloosaa in forum Mac Chat
    Last Post: 26th March 2012, 02:19 AM
  4. Fedora 11 - Speakers not producing sound
    By rockraider in forum EOL (End Of Life) Versions
    Last Post: 21st September 2010, 10:50 AM
  5. Fedora 11 - Speakers not producing sound
    By rockraider in forum Using Fedora
    Last Post: 21st September 2010, 07:39 AM
