2nd January 2020, 06:01 PM
Fedora 31: approved way to swap caps lock and control?
I'm looking at settings->devices and see keyboard shortcuts but not simply keyboard.
I know many old school ways to do this but I'm wondering if there's a way specific to this GUI/toolkit.
3rd January 2020, 02:19 AM
Re: Fedora 31: approved way to swap caps lock and control?
You might take a look at an older thread https://forums.fedoraforum.org/showt...-keyboard-keys. This discusses xmodmap and its gui front end xkeycaps.
4th January 2020, 10:06 AM
Thanks Jims. I've used xmodmap since like 1989 but I'm never sure how far these integrated session managers want to control things, and often once the session manager has a way it wants to do it, you cause yourself trouble by trying to do anything else. So I'm just checking if that's the case with keyboard maps. I can't even figure out what default session manager it's bundled but I hear it's gnome. Thanks again!
12th January 2020, 04:33 PM
OK, here's a specific answer.
Fedora ships with Gnome as the GUI. It lets you tweak some behavior with a utility called gnome-tweaks. Naturally, this program isn't even installed by default.
To install: dnf install gnome-tweak-tool
To run: gnome-tweaks
Go to: Keyboard & Mouse --> Additional Layout Options --> Caps Lock as Control
17th May 2020, 04:12 AM
i thought you'd found it Frank, and was going to send you a million dollars for saving my sanity, but it doesn't work for me in F32
still there may be something else useful gnome-tweaks can do; time will tell.
as for xmodmap, it has burned my fingers more than once and id rather not go near it again.
there was a simple solution in F29 (forget what it was now) but nothing seems to work in F32.
xkeycaps eh Jim? let's see... yes! ok Jim, where do i send the money?
By Jefftzs in forum Using Fedora
Last Post: 4th February 2013, 02:36 AM
By December in forum Using Fedora
Last Post: 15th October 2011, 06:27 AM
By vetkasi in forum Using Fedora
Last Post: 10th June 2009, 10:18 PM
By halloo in forum Using Fedora
Last Post: 8th December 2008, 08:40 PM
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
[[template footer(Guest)]]
