HP OfficeJetPro 7720 problem
    Feb 2009
    20
    Hello-Just bought the above but software to run it does not run. Software to run is hplip 3.19.8.run obtained from Sourceforge.net. Failure stated "fail to install files:not supported. I use Fedora core 30. All ideas will be most welcome.
    Doozle
    Apr 2009
    central NY, USA
    1,433
    3 Post(s)
    Re: HP OfficeJetPro 7720 problem
    Have you tried installing hplip from your repos (if available) using dnf - as opposed to trying to import a '.run' file with dependencies unknown? If available, repos are always the preferred method.
    {Just a suggest/hint as I don't know what's available in Fedora anymore}
    Remember - importing/building packages will likely "byte you in the butt" come update/upgrade time, long after you'd forgotten you did that! Use repos whenever possible.
    May 2015
    Boston
    65
    https://developers.hp.com/hp-linux-i..._devices/index
    It is a supported printer, however the above web page is chopped off at the right side (also in multiple browsers), so it's not displaying all of the connection method column. It is showing "Network", but nothing else. It's possible that it may be a network-only printer.
    Jan 2012
    auckland
    135
    https://developers.hp.com/hp-linux-i..._devices/index shows hplip 3.17.9, network printer only..
  1. google problem? fedora problem? my problem?
    By FedoraFTW in forum Using Fedora
    Last Post: 23rd January 2018, 04:57 PM
  2. DELL Inspiron 7720 driver problems
    By pentarh in forum Hardware & Laptops
    Last Post: 3rd May 2013, 04:50 PM
  3. Inspiron 7720 touchpad woes in F18
    By KerrMD in forum Hardware & Laptops
    Last Post: 20th April 2013, 01:01 PM
  4. Wireless support on Acer Aspire 7720
    By ramonakkk in forum Servers & Networking
    Last Post: 10th January 2010, 05:37 PM
  5. Acer Aspire 7720 function and volume keys
    By Scirious in forum Hardware & Laptops
    Last Post: 2nd May 2008, 02:41 AM
