Kernel 5.2.11 no sound card found
    Aug 2019
    U.S
    4
    Angry Kernel 5.2.11 no sound card found
    After update the kernel today, fedora cannot recognize any sound card and give dummy output.
    lspci | grep -i audio command gives
    0a:00.1 Audio device: NVIDIA Corporation TU102 High Definition Audio Controller (rev a1)
    0c:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
    but in alsamixer, no sound card can be found.
    I have motherboad Gigabyte X570 master
    Thank you.
    Sep 2016
    Frankfort, Germany
    129
    Re: Kernel 5.2.11 no sound card found
    can't confirm that. Up to now it works so far.
    Aug 2019
    U.S
    4
    what to confirm ? It is the situation I have right now and what I have done is run dnf update -y in the terminal which update the kernel from 5.2.9 to 5.2.11
Name:	Screenshot from 2019-09-06 14-53-39.png
Name:	Screenshot from 2019-09-06 15-10-44.png
    ADD the also-info.txt screenshot
Name:	Screenshot from 2019-09-06 15-21-53.jpg
  1. VIA Sound Card not Found in ALSA on F13
    By tim273 in forum Using Fedora
    Last Post: 12th September 2010, 03:37 AM
  2. FC10 no sound card found?
    By MrUmunhum in forum Using Fedora
    Last Post: 27th April 2009, 01:35 AM
  3. Alsaconf says no sound card found
    By manojabala in forum Using Fedora
    Last Post: 14th February 2009, 01:38 PM
