Virtual box help needed - host networking
    Aug 2019
    Malaysia
    3
    hello folks.
    i am unable to create host networking virtualbox 6.0. when i try to start getting the below error.
    what kernal version should i use for virtualbox6.0 and fedora 30 i am currently using.
    [root@localhost yum.repos.d]# /usr/lib/virtualbox/vboxdrv.sh restart
    vboxdrv.sh: Stopping VirtualBox services.
    vboxdrv.sh: Starting VirtualBox services.
    vboxdrv.sh: Building VirtualBox kernel modules.
    This system is currently not set up to build kernel modules.
    Please install the Linux kernel "header" files matching the current kernel
    for adding new hardware support to the system.
    The distribution packages containing the headers are probably:
    kernel-devel kernel-devel-5.2.6-200.fc30.x86_64
    [root@localhost yum.repos.d]# modinfo vboxdrv
    modinfo: ERROR: Module vboxdrv not found.
    Mar 2012
    Frankfurt
    87
    Re: Virtual box help needed - host networking
    I ll add a question. Can I limit with this sandbox the CPU?
    Jan 2010
    7,454
    For the first question, they give you the answer. While this article is somewhat dated, it's still accurate, it goes into making sure your kernel and kernel-devel files are in sync. (I believe Fedora will install headers with kernel-devel)
    http://srobb.net/rhkerndev.html
    The original article mentions the PAE kernel, I don't even know if they still have that, but the issue is the kernel and kernel-header files have to be in sync.
  1. Host to VM networking and VM to Host networking
    By edward_c in forum Servers & Networking
    Last Post: 8th March 2013, 12:09 PM
  2. KVM Virtual Host + autostart VMs locking up host
    By doctorpacket in forum Servers & Networking
    Last Post: 16th December 2009, 11:26 AM
  3. Mail Server with Virtual Host and Virtual Domains
    By ssdude in forum Servers & Networking
    Last Post: 2nd May 2009, 03:45 PM
  4. Host Only Networking on KVM
    By bjrosen in forum Servers & Networking
    Last Post: 10th June 2008, 11:01 PM
