SATA controller card for Linux ASM1062 doesn't work
    Mar 2018
    Vermont, USA
    136
    I tried to add HD, and needed extra sata ports. I got a ASM1062 PCI ata Controller card nstalled - lspci shows the card, it shows up in the bios and is set to AHCI in bios...
    I now read in the 'readme' that it is not supported for any versions of linux (but it still is recognized by the system. I am happy to purchase another card that is supported for Linux, and any suggestions would be helpful
    Meanwhile - is there a way I might get Linux to get the card working ? I have the windows driver disk ....
    Regards,
    * Bill Clark Windham, VT *
    Mar 2018
    Vermont, USA
    136
    Re: SATA controller card for Linux ASM1062 doesn't work
    OK - I cannot locate a site that lists sata controller boards which are linux compatible - any suggestions ? I am not searching correctly, I suppose..
  1. After preupgrade: F15 doesn't recognize sata disks connected thru Marvell controller
    By andyzhu35 in forum Installation, Upgrades and Live Media
    Last Post: 11th September 2011, 09:18 PM
  2. patch for Sata + IDE Raid controller card
    By TwoWheels in forum Hardware & Laptops
    Last Post: 1st May 2008, 08:45 AM
  3. SATA Raid Controller Card ?
    By DeadPenguin in forum Using Fedora
    Last Post: 1st February 2005, 03:55 AM
  4. what SATA RAID controller will work?
    By scottlindner in forum Hardware & Laptops
    Last Post: 15th December 2004, 06:03 PM
