Dispay issues since kernel 5.2.x with Ryzen 3400G | Fedora 30 - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
    106
    Re: Dispay issues since kernel 5.2.x with Ryzen 3400G | Fedora 30
    If fedora 31 comes out with one of the broken kernels(coming soon), I guess we are stuck where we are....
    Mar 2019
    Netherlands
    20
    New Kernel 5.2.9 still the same issues. Now I start to get worried that I still get a black screen. Still on 5.1.20.
    106
    Well, if you look at the bug report: https://bugzilla.kernel.org/show_bug.cgi?id=204325
    It shows it it labeled " Importance: P1 blocking"....
    I thought P1 means that they can't release the next version until it is solved....
    But I guess that is not the next version of 5.2.x - But the first 5.3 version(in about a month)????
  4. #19
    Oct 2005
    Puerto Rico
    601
    Hi everyone. I was about to post a new thread but think I have this same issue. I upgraded my wife's workstation with a AMD motherboard and a SSD HD. F30 live usb and initial install went OK. After a full update I started getting video distortions. The new video card is a Ryzen 5 2400g. I am attaching screenshots shown the distortions and some additional info.
ID:	30519Click image for larger version.
ID:	30520Click image for larger version.
    Can anyone confirm this to be the same issue? Further, there is another thread in this same forum that looks similar:
    HTML Code:
    https://forums.fedoraforum.org/showthread.php?322167-Display-garbled-after-Upgrade-FC28-to-FC29
    Suspecting a kernel problem, I found no way to make the workstation to boot using the original installation kernel in order to wait for a fix, but Plymouth does not allow me to choose the appropriate one. Any advice? Thanks.
    I found out how to boot with the original kernel and the distortions are now gone.
  5. #20
    Mar 2019
    Netherlands
    20
    I had the same issues after 5.1.20. But latest 2 kernels I only get a black screen after login.
  6. #21
    Jul 2004
    Wake Forest, NC
    65
    1,469
    Are you using nomodeset in your grub.cfg? When I installed F30 on my new HP laptop with Ryzen 3 processor, I had to use the basic graphics to get a screen. After installing though, I was only getting 1024x768 screen resolution. Then I looked at the grub parameters at boot time and noticed that it included nomodeset. I removed that and got a lot better resolution of 1366x68 which looks a whole lot better.
    I was also getting the black screen upon waking up the laptop from suspension. The latest kernel and verifying that the amdgpu kernel module was there seems to have fixed it, bu it is a bit soon to say for sure. I did install xorg-x11-drv-amdgpu-19.0.1-1.fc30.x86_64 which also likely helped.
    StephenH
    "We must understand the reality that just because our culture claims certain things are true it does not mean they are!" --M. Liederbach
    http://pilgrim-wanderings.blogspot.com
  7. #22
    Mar 2019
    Netherlands
    20
    At Kernel 5.2.11 still not solved. For the time being I switched from XFCE to Cinnamon desktop.
  8. #23
    Oct 2005
    Puerto Rico
    601
    Hmmm... My wife's workstation seems to be doing just find after installing the 5.2.11 kernel. I installed it along with a bunch of updates including video drivers, so not sure if this is a combination of factors.
  9. #24
    Mar 2019
    Netherlands
    20
    Quote Originally Posted by Boricua
    I have a 3400G - ASRock B450 Pro4 with latest uefi - 2x8Gb Corsair Vengeance LPX CMK16GX4M2B3000C15. Only issues with XFCE. Cinnamon and KDE works well. I don't think I need to install seperate video drivers.
    My main pc with a 2700x, MSI Tomahawk, Radeon RX 580 8gb and G.Skill Ripjaws V F4-3200C14D-16GVK no issues. That works well with XFCE.
  10. #25
    106
    I just tried 5.2.11 with all the updates - and still NO GO....
    5.3.x will be out in a couple of weeks.... If it still isn't fixed I will be Very Disappointed - to say the least....
    as previously stated - the bug is labeled " Importance: P1 blocking", which I believe(correct me if I am wrong) means MUST BE FIXED before releasing next version(5.3.x)....
  1. Fedora 27, AMD Ryzen 2400G, and Gigabyte AB350N issues
    By aleahy in forum Hardware & Laptops
    Last Post: 4th March 2018, 11:25 AM
  2. Running Fedora 26 in Ryzen 7 1700
    By pingwu in forum Hardware & Laptops
    Last Post: 29th November 2017, 09:04 PM
  3. Install Ryzen 7 1700 with Fedora 26
    By nobody in forum F26 Development Forum
    Last Post: 5th June 2017, 05:51 PM
  4. Ryzen first experiences SUSE user has Ryzen
    By lsatenstein in forum Linux Chat
    Last Post: 22nd April 2017, 08:50 PM
  5. Install Ryzen 1700 with Fedora 25
    By samphar in forum Installation, Upgrades and Live Media
    Last Post: 24th March 2017, 06:18 AM
