Live USB Works Fine - Install on Hard Drive Not So Much
    May 2019
    us
    I pulled down the live image and created a bootable USB drive to test on my HP Spectre 15" laptop. The live image running from the USB works fine. Picks up Wifi, graphics card, bluetooth, etc. As far as I could tell everything was working, even the touch screen. I decided to take the plunge and install to the hard drive. Sadly most of the devices wouldn't work with the hard drive install. No Wifi, Bluetooth or even the track pad. Any particular reason it would work fine from the USB but not the hard drive?
    Thanks, Jeff...
    Apr 2009
    central NY, USA
    1,233
    1 Post(s)
    Re: Live USB Works Fine - Install on Hard Drive Not So Much
    While you may, I would never recommend an install from a "Live" version. If you like how the live version worked with your machine, download and install a full version with all the necessary drivers, support files, utilities, etc. - that you're going to wind up trying to install manually afterwards. A "live" install is so VERY minimal. It works, but ... ;-)
    Change - the only constant.
    May 2019
    us
    Thank for the reply. It was actually from the Fedora installer. I downloaded the desktop version and used the Fedora writer to create the USB drive. It gives you the option to run/trial the OS or install it to the hard drive. Worked fine from the USB, not from the hard drive.
  1. install Live CD to hard drive with old version on there already
    By bubazoo in forum Installation, Upgrades and Live Media
    Last Post: 14th August 2010, 10:41 PM
  2. Replies: 5
    Last Post: 12th December 2008, 05:27 PM
  3. Replies: 5
    Last Post: 1st March 2008, 02:46 AM
  4. Replies: 2
    Last Post: 10th September 2007, 09:57 AM
  5. FC7 Live CD - Install to hard drive issue
    By rosen_gj in forum Installation, Upgrades and Live Media
    Last Post: 8th June 2007, 04:24 PM
