[SOLVED] Fuse problem? with latest Fedora 29 update and Fedora 30
    Feb 2015
    Colorado
    49
    After the latest Fedora 29 update I installed today, and with Fedora 30 it seems as though fuse is broken.
    Fedora workstation runs fine until I do the following command:
    $ sshfs user@myserver:/server /home/user/Server
    which would make the partition /server on myserver appear as a local partition /home/user/Server on the workstation.
    Now when I do this, Nautilus (Files) takes forever to launch (if at all) and when it eventually does, Nautilus is broken.
    Rhytmbox, and gnome-tweaks also takes a long time to launch if at all.
    ssh works fine, I can ssh into myserver ok and everything looks good.
    On the client workstation, I tried using both Wayland and Gnome on Xorg, still fails either way.
    Now I can't access any of my files on the server. Any suggestions on mounting my server via a different route until fuse is fixed would be appreciated.
    I will try to post a screenshot of the broken Nautilus shortly.
    I try to think, but nothin' happens!
    Feb 2015
    Colorado
    49
    Re: Fuse problem? with latest Fedora 29 update and Fedora 30
    Okay, I walked away from the computer and cleared my mind. Then I started going back through my previous troubleshooting steps very slowly.
    In the Original Post, I said I could ssh into the server computer. I had so many theories going through my mind that it didn't even register that I had to enter the password for the server user. That was a red flag I missed. It looked like the ssh keys was at least part of the problem. While I was ssh'ed into the server anyway, I edited the authorized_keys file and removed my old client public key.
    In the client computer as my user, I removed the .ssh folder from my home folder, thus removing all current keys.
    Then i regenerated new ssh keys using ssh-keygen.
    Next I used ssh-copy-id to copy my new id_rsa.pub file to the server computer.
    I used ssh to remotely access the server and voila, no password entry was required.
    in the client computer I entered the sshfs user@myserver:/server /home/user/Server
    and it worked!
    Then for grins, I updated the server to the latest packages, and everything still worked.
    So that again tells me the problem was probably in FUSE and not SSH????
    All's well that ends well.
  1. Problem with Bluetooth sound after latest update on Fedora 23
    By kimmason in forum Hardware & Laptops
    Last Post: 24th April 2016, 07:16 PM
  2. Fedora freezing after latest update.
    By noviceFedora in forum Using Fedora
    Last Post: 2nd January 2016, 08:43 PM
  3. Replies: 3
    Last Post: 5th December 2009, 03:27 PM
