Opinions about nextcloud used through provider
    Apr 2018
    Finland
    113
    Hi.
    I'm sloooowly moving away from google stuff and been looking for alternatives for googles services. (Like posteo for email and (maybe someday) LBRY for youtube).
    Nextcloud seems to be amazing option for cloud storage. But as I don't want to run server myself and I'm not tech savvy enough to conformable run Nextcloud from virtual machine, and for my usage I prefer just "register and start using" kind of solution. So I created the free Nextcloud account(probably wrong term) provided by webo.hosting and it seems to work great. But I've slight concerns about how much I can trust them with my data. Stuff that I have read from their page about how they use data and stuff like that seems ok. Seems like if I have trusted google with my data should be able to trust webo.hosting too?
    Any opinions about this kind of stuff?
    Jul 2013
    NZ
    454
    Re: Opinions about nextcloud used through provider
    Just encrypt everything in your nextcloud folder. I do run a nextcloud server myself using a Digitalocean "droplet" running CentOS 7, which is also running a wordpress site. I found Digitalocean have lots of very good tutorials for a server newb like me. The biggest hassle was that I needed php 7 or greater, which you don't get with the normal CentOS 7 repos, so I ended up installing it alongside the old version using the Software Collections scheme = https://www.softwarecollections.org/en/. I'm not sure now that this was the best way to go as I have since discovered that there is a repo available called rpms.remirepo.net, which might be a good solution assuming it can be trusted. I notice the upcoming redhat 8 has a thing called "application streams" which sounds like it might address the problem of out of date packages in a better way.
    Anyway the nextcloud is used for a club I am involved with to keep all our documents. We moved away from dropbox because the club files were robbing quota from the each users personal dropbox account. Nextcloud has worked well for the five months we have been using it.
    Correct selinux context for nextcloud directory?
    By jonathonp in forum Security and Privacy
    Last Post: 28th November 2018, 10:42 AM
  2. How do i install nextcloud?
    By Linuxdude in forum Installation, Upgrades and Live Media
    Last Post: 16th May 2017, 02:09 AM
  3. KDE can't manage owncloud/nextcloud accounts?
    By stratacast1 in forum Fedora Spins & Remixes
    Last Post: 21st April 2017, 12:47 AM
  4. [SOLVED]
    New package suggestion (Nextcloud)
    By stratacast1 in forum Programming & Packaging
    Last Post: 4th October 2016, 06:17 AM
  5. nextcloud or owncloud
    By zuser in forum Office/Productivity Software
    Last Post: 29th June 2016, 06:55 PM
