Help me to clean my PC by BleachBit
Results 1 to 8 of 8
    Aug 2016
    Iraq
    1,016
    Hi. It is now 3 year since being Fedora user, from Fedora 24 to 26 to 28
    Till now I did not use BleachBit in strong way, being using it as non-root & only for following things - please see the following screenshots from above downward:
    Even with above selection, I received error message "premission denied" (I think program need to be run with sudo to achieve them) - see the errors bellow:
    [Errno 13] Permission denied: '/var/log/lightdm/seat0-greeter.log.old': Command to delete /var/log/lightdm/seat0-greeter.log.old
    [Errno 13] Permission denied: '/var/log/lightdm/lightdm.log.old': Command to delete /var/log/lightdm/lightdm.log.old
    [Errno 13] Permission denied: '/var/log/lightdm/x-0-greeter.log.old': Command to delete /var/log/lightdm/x-0-greeter.log.old
    [Errno 13] Permission denied: '/var/log/lightdm/x-2.log.old': Command to delete /var/log/lightdm/x-2.log.old
    [Errno 13] Permission denied: '/var/log/lightdm/x-0.log.old': Command to delete /var/log/lightdm/x-0.log.old
    [Errno 13] Permission denied: '/var/log/lightdm/x-1.log.old': Command to delete /var/log/lightdm/x-1.log.old
    [Errno 13] Permission denied: '/var/log/lightdm/x-1-greeter.log.old': Command to delete /var/log/lightdm/x-1-greeter.log.old
    [Errno 13] Permission denied: '/var/log/Xorg.2.log.old': Command to delete /var/log/Xorg.2.log.old
    [Errno 13] Permission denied: '/var/log/Xorg.0.log.old': Command to delete /var/log/Xorg.0.log.old
    [Errno 13] Permission denied: '/var/log/Xorg.1.log.old': Command to delete /var/log/Xorg.1.log.old
    [Errno 13] Permission denied: '/var/log/spooler-20190319': Command to delete /var/log/spooler-20190319
    [Errno 13] Permission denied: '/var/log/dnf.rpm.log-20190326': Command to delete /var/log/dnf.rpm.log-20190326
    [Errno 13] Permission denied: '/var/log/secure-20190311': Command to delete /var/log/secure-20190311
    [Errno 13] Permission denied: '/var/log/dnf.librepo.log-20190319': Command to delete /var/log/dnf.librepo.log-20190319
    [Errno 13] Permission denied: '/var/log/secure-20190402': Command to delete /var/log/secure-20190402
    [Errno 13] Permission denied: '/var/log/dnf.log-20190319': Command to delete /var/log/dnf.log-20190319
    [Errno 13] Permission denied: '/var/log/secure-20190326': Command to delete /var/log/secure-20190326
    [Errno 13] Permission denied: '/var/log/btmp-20190401': Command to delete /var/log/btmp-20190401
    [Errno 13] Permission denied: '/var/log/dnf.rpm.log-20190319': Command to delete /var/log/dnf.rpm.log-20190319
    [Errno 13] Permission denied: '/var/log/maillog-20190326': Command to delete /var/log/maillog-20190326
    [Errno 13] Permission denied: '/var/log/dnf.librepo.log-20190311': Command to delete /var/log/dnf.librepo.log-20190311
    [Errno 13] Permission denied: '/var/log/messages-20190326': Command to delete /var/log/messages-20190326
    [Errno 13] Permission denied: '/var/log/dnf.librepo.log-20190402': Command to delete /var/log/dnf.librepo.log-20190402
    [Errno 13] Permission denied: '/var/log/cron-20190326': Command to delete /var/log/cron-20190326
    [Errno 13] Permission denied: '/var/log/wtmp-20190216': Command to delete /var/log/wtmp-20190216
    [Errno 13] Permission denied: '/var/log/spooler-20190402': Command to delete /var/log/spooler-20190402
    [Errno 13] Permission denied: '/var/log/dnf.rpm.log-20190311': Command to delete /var/log/dnf.rpm.log-20190311
    [Errno 13] Permission denied: '/var/log/dnf.log-20190326': Command to delete /var/log/dnf.log-20190326
    [Errno 13] Permission denied: '/var/log/secure-20190319': Command to delete /var/log/secure-20190319
    [Errno 13] Permission denied: '/var/log/cron-20190319': Command to delete /var/log/cron-20190319
    [Errno 13] Permission denied: '/var/log/messages-20190402': Command to delete /var/log/messages-20190402
    [Errno 13] Permission denied: '/var/log/maillog-20190402': Command to delete /var/log/maillog-20190402
    [Errno 13] Permission denied: '/var/log/dnf.rpm.log-20190402': Command to delete /var/log/dnf.rpm.log-20190402
    [Errno 13] Permission denied: '/var/log/spooler-20190311': Command to delete /var/log/spooler-20190311
    [Errno 13] Permission denied: '/var/log/spooler-20190326': Command to delete /var/log/spooler-20190326
    [Errno 13] Permission denied: '/var/log/messages-20190319': Command to delete /var/log/messages-20190319
    [Errno 13] Permission denied: '/var/log/maillog-20190311': Command to delete /var/log/maillog-20190311
    [Errno 13] Permission denied: '/var/log/messages-20190311': Command to delete /var/log/messages-20190311
    [Errno 13] Permission denied: '/var/log/cron-20190311': Command to delete /var/log/cron-20190311
    [Errno 13] Permission denied: '/var/log/maillog-20190319': Command to delete /var/log/maillog-20190319
    [Errno 13] Permission denied: '/var/log/hawkey.log-20190326': Command to delete /var/log/hawkey.log-20190326
    [Errno 13] Permission denied: '/var/log/hawkey.log-20190402': Command to delete /var/log/hawkey.log-20190402
    [Errno 13] Permission denied: '/var/log/cron-20190402': Command to delete /var/log/cron-20190402
    [Errno 13] Permission denied: '/var/log/dnf.log-20190311': Command to delete /var/log/dnf.log-20190311
    [Errno 13] Permission denied: '/var/log/dnf.librepo.log-20190326': Command to delete /var/log/dnf.librepo.log-20190326
    [Errno 13] Permission denied: '/var/log/hawkey.log-20190319': Command to delete /var/log/hawkey.log-20190319
    [Errno 13] Permission denied: '/var/log/hawkey.log-20190311': Command to delete /var/log/hawkey.log-20190311
    [Errno 13] Permission denied: '/var/log/dnf.log-20190402': Command to delete /var/log/dnf.log-20190402
    [Errno 13] Permission denied: '/var/log/cups/page_log-20180927': Command to delete /var/log/cups/page_log-20180927
    [Errno 13] Permission denied: '/var/log/cups/error_log-20181121': Command to delete /var/log/cups/error_log-20181121
    [Errno 13] Permission denied: '/var/log/cups/page_log-20181121': Command to delete /var/log/cups/page_log-20181121
    [Errno 13] Permission denied: '/var/log/cups/page_log-20181223': Command to delete /var/log/cups/page_log-20181223
    [Errno 13] Permission denied: '/var/log/cups/page_log-20180918': Command to delete /var/log/cups/page_log-20180918
    [Errno 13] Permission denied: '/var/log/cups/error_log-20180918': Command to delete /var/log/cups/error_log-20180918
    [Errno 13] Permission denied: '/var/log/cups/access_log-20180927': Command to delete /var/log/cups/access_log-20180927
    [Errno 13] Permission denied: '/var/log/cups/error_log-20181223': Command to delete /var/log/cups/error_log-20181223
    [Errno 13] Permission denied: '/var/log/cups/access_log-20181121': Command to delete /var/log/cups/access_log-20181121
    [Errno 13] Permission denied: '/var/log/cups/access_log-20181223': Command to delete /var/log/cups/access_log-20181223
    [Errno 13] Permission denied: '/var/log/cups/access_log-20180918': Command to delete /var/log/cups/access_log-20180918
    [Errno 13] Permission denied: '/var/log/cups/error_log-20180927': Command to delete /var/log/cups/error_log-20180927
    I have slow boot time (2 minutes + 37 seconds), & I like to clean my system from old not needed files that collected over 3 years of continuous usage ...
    However, I'm afraid from breaking of my system if I select items to be cleaned that should not cleaned & to run program with such selections using sudo .....
    Kindly, please to help me: I would like some one expert to give me the advanced selection options (all options that THEY ARE SAFE TO SELECT & to run with sudo) without risk to break my system .....
    Fedora 28 X64 bit Cinnamon edition on Lenovo ThinkPad e550 with Intel core i7 5500 CPU @ 2.40 GH X 2, RAM = 8 GB, HHD = 1 TB, Hybrid VGA (Intel Corporation HD Graphic 5500 + Radeon R7 M265 2GB)
    5,868
    Re: Help me to clean my PC by BleachBit
    Hi User808
    /var is owned by root. Most of the deletes within /var are for logs.
    Since you have the list of logs, you could sudo rm -i /var/log/*.log and select and remove old logs.
    The next time that software has to write to a log, and it is not there, most software will recreate a logfile
    Dec 2011
    76
    May be also read up on logrotate once you have cleaned matters up. You can define how far back you want to keeps logs; avoids you having to do the same manual clean up in future
    5,868
    Quote Originally Posted by pindakoe
    We forgot to mention that we can also establish the max size of a logfile.
    Aug 2016
    Iraq
    1,016
    Hi I found other nice GUI application called "Optimizer" can clean applications caches & log files without need to run it as root ffrom within terminal.
    sudo dnf install optimizer
    It show me the following: 4.1 GB log files in /var/log & 1.2 GB applications caches in home/myusername/.cache
    I would like to know:
    1) is there a side effect from removing log files that can cause problems ?
    2) is removal of applications caches will result, for example, in removing my bookmarks & login creadentials that I already saved in Firefox & other applications ? Does this will result in deletions of keyring keys & PGP keys that stored on my system ?
    3) does deletions of log files & applications caches will improve my currently slow booting time ?
    5,868
    Instead or removing logfiles, you could zero them out.
    Sudo echo '' > logfiles.log
    Aug 2016
    Iraq
    1,016
    I used Optimizer to remove ALL log files. I removed 4.1 GB. No any adverse side effects ......
    However, the applications caches I did not touch it till now. I examine it & noticed the following: of 1.3 GB applications cache there is 705.7 MB in Tracker cache + 320.5 MB in gnome-software
    I think it is better to deal with applications caches manually.
    1) regarding Tracker cache: is it of any important ? From where it generated to reach such huge size ? Is total removal of it has adverse side effects ?
    2) regarding gnome-software cache: I have following subfolders - see screenshot bellow:
    What are your opinions ? Which is (are) safe to delete/empty ?
    Jan 2015
    Al Ain, UAE
    846
    Howdy,
    It is a waste of time to clean up logs manually.
    Edit the logrotate.conf file and the system will do it automatically for you:
    https://linux.die.net/man/8/logrotate
    Have fun!
    http://www.aeronetworks.ca
  1. Run bleachbit as root
    By rick1959 in forum Using Fedora
    Last Post: 3rd May 2017, 02:28 PM
  2. BleachBit & F25
    By End-User in forum Using Fedora
    Last Post: 30th March 2017, 03:11 AM
  3. BleachBit question
    By patrick013 in forum Using Fedora
    Last Post: 5th August 2011, 09:36 PM
  4. Bleachbit in Fedora 15
    By bluesh3ll in forum Using Fedora
    Last Post: 11th June 2011, 06:45 PM
  5. I want to update Bleachbit.
    By Pink Panther in forum Using Fedora
    Last Post: 13th October 2009, 08:10 PM
