[SOLVED] Ralink Technology, Corp. Adapter wireless MT7601U Would you help me find and install
Results 1 to 6 of 6
    Oct 2015
    Sondrio Valtellina
    42
    206
    Can someone help me find and install the right drivers for the device please?
    7,099
    5 Post(s)
    1 Thread(s)
    Re: Ralink Technology, Corp. Adapter wireless MT7601U Would you help me find and inst
    Ralink were taken over by MediaTek and they have not released any module updates for a couple of years for your device.
    if it's not working with current kernels, there aren't any current modules you can add for this device. support was supposedly added for it in kernel 4.2 but that said it may have been removed or dropped since. if your system has an internal wireless adaptor you need to try disabling that so the usb ralink is not blocked by interference.
    Oct 2015
    Sondrio Valtellina
    42
    206
    And an antenna to boost signal with even 5G (given my notebook has only 2.4) but that enjoys a good support with Fedora and possibly an easy installation what would you recommend??
    7,099
    5 Post(s)
    1 Thread(s)
    Quote Originally Posted by xzj8b3
    I make a point of not recommending USB devices since they are hit and miss with Linux. The vendors alternate between different makes of chipset so it's hard to tell what you are getting really until you actually plug the device in these days.
    You can use this page as a reference but again, what is written there may be out of date as per your ralink device support status.
    However, if it were me I'd carry on using the internal device since it actually works. Both 5 GHz and 2.4 GHz WLAN have benefits, 2.4 GHz may be slower but it has better signal strength through walls and further away from the router.
    Oct 2015
    Sondrio Valtellina
    42
    206
    Smile Re: Ralink Technology, Corp. Adapter wireless MT7601U Would you help me find and inst
    I know in the future I better decide to change routers and take one seriously that at that point I would really have the advantages!!!!
    Oct 2015
    Sondrio Valtellina
    42
    206
    Is there any terminal method to make the signal more stable with Fedora?
  1. Ralink RT5572 Wireless Adapter not working anymore
    By clamb in forum Servers & Networking
    Last Post: 3rd February 2016, 02:34 PM
  2. Replies: 0
    Last Post: 10th August 2012, 08:33 AM
  3. Wireless Connection Problem with Ralink USB Adapter
    By gbaaseng in forum Servers & Networking
    Last Post: 15th January 2010, 05:17 AM
  4. whr can i find ralink wireless lan adapter driver?
    By anirudh.anu001 in forum Hardware & Laptops
    Last Post: 19th January 2009, 02:38 PM
  5. Unable to find IP of wireless adapter
    By iceburn in forum Installation, Upgrades and Live Media
    Last Post: 10th June 2007, 03:17 AM
