rtl8821ce doesn't work on Fedora 29 - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
  1. #31
    May 2018
    UK
    204
    Re: rtl8821ce doesn't work on Fedora 29
    So it compiled this time but you still get no wifi? It definitely is an RTL8821CE and not some other variant? Also did you remember to turn off secure boot in the BIOS to allow the newly compiled module to load?
    Could you post the output of the following commands.
    lspci | grep RTL
    dkms status
    mokutil --sb-state
    modprobe 8821ce
  2. #32
    May 2018
    UK
    204
    It looks like it didn't get installed properly even though dkms thinks it is, so it may be worth deleting the dkms stuff ( sudo rm -rf /var/lib/dkms/rtl8821ce ) and trying again in case there was something left from previous attempts.
    You could also check to see if there is anything interesting in the logs
    sudo journalctl -b | grep 8821
  3. #33
    Mar 2019
    Pathum Thani, THAILAND
    42
    1 Post(s)
    This is the result.
    [fedora000@localhost ~]$ sudo journalctl -b | grep 8821
    [sudo] password for fedora000:
    Mar 16 22:53:15 localhost.localdomain kernel: Bluetooth: hci0: RTL: rtl: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
    Mar 16 22:53:15 localhost.localdomain kernel: Bluetooth: hci0: RTL: rtl: loading rtl_bt/rtl8821c_fw.bin
    Mar 16 22:53:15 localhost.localdomain kernel: Bluetooth: hci0: RTL: rtl: loading rtl_bt/rtl8821c_config.bin
    Mar 16 22:53:34 localhost.localdomain sh[860]: { 'make' -j4 KVER=4.20.14-200.fc29.x86_64; } >> /var/lib/dkms/rtl8821ce/v5.2.5_1.26055.20180108.1/build/make.log 2>&1
    Mar 16 22:53:34 localhost.localdomain sh[860]: Consult /var/lib/dkms/rtl8821ce/v5.2.5_1.26055.20180108.1/build/make.log for more information.
  4. #34
    May 2018
    UK
    204
    And is there any obvious fatal error in /var/lib/dkms/rtl8821ce/v5.2.5_1.26055.20180108.1/build/make.log which it is telling you to consult?
    EDIT: Maybe it is something obvious like compiler not installed.
    sudo dnf  install gcc glibc-devel glibc-headers cpp
    Then try again.
  5. #35
    Mar 2019
    42
    1 Post(s)
    DKMS make.log for rtl8821ce-v5.2.5_1.26055.20180108.1 for kernel 4.20.15-200.fc29.x86_64 (x86_64)
    Wed Mar 20 14:14:37 +07 2019
    /usr/sbin/dkms: line 92: make: command not found
    [fedora000@localhost ~]$ sudo dnf install gcc glibc-devel glibc-headers cpp
    Fedora Modular 29 - x86_64 2.7 kB/s | 8.0 kB 00:02
    Fedora Modular 29 - x86_64 - Updates 2.9 kB/s | 8.2 kB 00:02
    Fedora 29 - x86_64 - Updates 1.9 kB/s | 6.0 kB 00:03
    Fedora 29 - x86_64 - Updates 199 kB/s | 24 MB 02:05
    Fedora 29 - x86_64 3.8 kB/s | 8.1 kB 00:02
    Package gcc-8.3.1-2.fc29.x86_64 is already installed.
    Package glibc-devel-2.28-26.fc29.x86_64 is already installed.
    Package glibc-headers-2.28-26.fc29.x86_64 is already installed.
    Package cpp-8.3.1-2.fc29.x86_64 is already installed.
    Dependencies resolved.
    Nothing to do.
    Complete!
  6. #36
    Mar 2019
    42
    1 Post(s)
    And now the screen is as attached herewith.
    Attachment 30179
  7. #37
    May 2018
    UK
    204
    Well that's a fairly obvious fatal error! You don't have make installed.
    sudo dnf install make
    And try again.
  8. #38
    Mar 2019
    42
    1 Post(s)
    Thank you so much for your kind support.
    And I appreciate how patient you were while I was looking for your assistance step by step for I am very new to Linux and Fedora.
    Finally Fedora 29 Workstation on my notebook can find Wi-Fi adapter and connect smoothly.
    I would like to summarize the procedure for the other people as follows:
    sudo dnf install -y make git kernel-headers kernel-devel elfutils-libelf-devel
    reboot
    sudo dnf install -y dkms
    reboot
    git clone https://github.com/tomaspinho/rtl8821ce
    reboot
    cd rtl8821ce
    chmod +x dkms-install.sh
    chmod +x dkms-remove.sh
    reboot
    sudo dnf --refresh upgrade
    reboot
    cd rtl8821ce
    sudo ./dkms-install.sh
    reboot
    Kidly review if it is correct or not.
  9. #39
    May 2018
    UK
    204
    Excellent news we got there in the end. The install of gcc glibc-devel glibc-headers cpp, didn't do anything/was not needed as were already installed - it was just me guessing what might be missing. What was actually the final missing component was "make" even though that should have been installed in the first step you listed above. I edited my original post to add in possibly missing dependencies and maybe I missed it out originally.
    The rm- rf line was only needed because the build failed leaving incomplete status in dkms.
    You shouldn't need to reboot so many times and repeat the steps. Basically if "make" had been installed at the start and we had rebooted once into the new kernel, you should have been up and running after the first (I've edited the sequence for clarity).
    sudo dnf -y upgrade
    Reboot now unless sure running kernel matches latest installed.
    Then
    cd rtl8821ce
    The problem was just in figuring out that it was "make" that was missing after we had the correct kernel.
    I have edited my original post in the thread to hopefully make things easier in future for others.
    Will rtl8821ce wireless driver be mainlined?
    By taztcs in forum Hardware & Laptops
    Last Post: 26th November 2018, 06:10 PM
  2. wifi issue realtek rtl8821ce HP Pavilion
    By bobatlcpmbdx in forum Hardware & Laptops
    Last Post: 5th September 2018, 10:32 PM
  3. Fedora 12 Kde doesn't work
    By decodedthought in forum Hardware & Laptops
    Last Post: 15th June 2010, 09:21 AM
  4. Mic doesn't work in Fedora 10
    By Wrenthir in forum Using Fedora
    Last Post: 22nd December 2008, 06:48 PM
  5. DVD rom doesn't work with fedora
    By solomon in forum Hardware & Laptops
    Last Post: 7th December 2008, 02:07 AM
