Fedora29 will not intall on an old Compaq Presario
    Feb 2019
    Texas
    Windows NT 10.0 Chrome 71.0.3578.98
    I downloaded and ISO version of fedora29 to conduct a fresh install of an old Compaq Presario SR1232om Desktop, along with two others, but with different hardware features. I installed the disk and got these error messages from all the selections to install the os to the older computer.
    Install fedora29 option:
Name:	install fedora29.jpg
    Test Media & Run Fedora Option
Name:	Test Media & Run Fedora.jpg
    Install Fedora in Basics Mode
    I know there are some fixes like installing some other executable files to make this work like for an issue I had with an Ubuntu install in the past. If there's a need of a hardware upgrade, that will cover most of what needs to be fixed for me to setup a render farm that I'm building, but keeping a low budget with the builds. Any idea of why it's causing this error?
    6,799
    Linux Firefox 65.0
    Re: Fedora29 will not intall on an old Compaq Presario
    the processor is most likely not supported by the current kernels. also you may struggle with the onboard graphics from kernel 5.0 onwards (if you are using them and not a GPU card) because the S3 unichrome driver has been dropped as well recently. your best option with hardware that old is to use a distribution that still offers LTS kernels that support it, eg. CentOS
  1. Compaq Presario 2309US
    By xarver in forum Hardware & Laptops
    Last Post: 27th July 2009, 10:38 PM
  2. compaq presario driver help
    By jithudigitised in forum Hardware & Laptops
    Last Post: 25th April 2007, 05:53 PM
  3. Compaq Presario M2000
    By appleman in forum Hardware & Laptops
    Last Post: 25th December 2005, 06:27 PM
  4. compaq presario v2310us
    By tryder in forum Using Fedora
    Last Post: 9th August 2005, 01:42 PM
