Keyboard will not accept any input ? (Fedora 29 Workstation - installed & works fine)
    Jan 2019
    Campbelltown, N.S.W AUSTRALIA.
    Windows NT 10.0 Chrome 71.0.3578.98
    Smile Keyboard will not accept any input ? (Fedora 29 Workstation - installed & works fine)
    Posted on 28-01-2019 at 11.24pm by Howard Pew.
    Hi everyone, or anyone seeing this message :-)
    Keyboard will not accept any input ? (Fedora 29 Workstation - installed & works fine).
    I installed Fedora 29 Workstation on my 2TB Hard Drive (full drive and full install).
    Everything went well with the install and everything worked fine after the install too,
    until sometime after I configured Fedora 29 to my liking.
    Now, Fedora 29 does not accept any input from my keyboard. It does however
    allow me to enter my password as usual, during bootup. I know there is no
    problems with my keyboard or drivers, for sure.
    Also, I have done a thorough investigation of all my Settings (config etc.)
    and have found nothing over there to produce the problem I am now having,
    with my keyboard (it is a Mechanical, USB cable type of keyboard).
    Can anyone help ?
    Kind regards,
    Howard Pew.
    Jan 2019
    Linux Chrome 72.0.3626.81
    Re: Keyboard will not accept any input ? (Fedora 29 Workstation - installed & works f
    Hello everyone, in reply to my original message, about a week ago,
    the only thing I thought I could do to fix my problem,
    was to simply re-install Fedora 29 Workstation on the
    hard-drive I originally had it on ?
    This of course worked fine, and I was more careful this time,
    in how I configured Fedora, in the Settings.
    So that finally fixed the problem I was having, with
    no input being accepted by my keyboard.
    Kind regards,
    Howard Pew.
  1. Replies: 14
    Last Post: 25th December 2009, 10:29 PM
  2. Replies: 8
    Last Post: 18th June 2009, 12:29 AM
  3. LiveCD wireless works fine, installed not so much
    By cautionbug in forum Alpha, Beta & Snapshots Discussions (Fedora 11 Only)
    Last Post: 24th May 2009, 05:28 PM
  4. I've installed gDesklets, and it works fine!
    By Alerander in forum Using Fedora
    Last Post: 18th August 2005, 01:17 PM
