WiFi adapter not detected after low battery suspension Fedora 29
    Jan 2019
    Piedmont NC, USA
    4
    Linux Firefox 65.0
    [RESOLVED]
    I have a Galago Pro running Fedora 29. The computer went into suspension because of low battery. Now, Fedora does not detect the wireless adapter -- meaning the gui manager returns "No WiFi adapter found...".
    The adapter was working correctly prior to the suspension.
    `rfkill list` shows no hard or soft block.
    `lspci` shows:
    03:00.0 Network controller: Intel Corporation Wireless 7260 (rev 73)
    Subsystem: Intel Corporation Dual Band Wireless-AC 7260
    Flags: bus master, fast devsel, latency 0, IRQ 32
    Memory at f7c00000 (64-bit, non-prefetchable) [size=8K]
    Capabilities: [c8] Power Management version 3
    Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
    Capabilities: [40] Express Endpoint, MSI 00
    Capabilities: [100] Advanced Error Reporting
    Capabilities: [140] Device Serial Number a0-a8-cd-ff-ff-df-ff-84
    Capabilities: [14c] Latency Tolerance Reporting
    Capabilities: [154] Vendor Specific Information: ID=cafe Rev=1 Len=014 <?>
    Kernel driver in use: iwlwifi
    Kernel modules: iwlwifi
    `ip link` shows:
    wlp3s0: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 1000
    link/ether a0:a8:cd:df:ff:84 brd ff:ff:ff:ff:ff:ff
    `ip link set wlp3s0 up` has no effect
    I have tried a hard (cold) reboot, restarting networking, and restarting network manager.
    Here is my system info
    6,799
    Windows NT 10.0 Chrome 71.0.3578.98
    Re: WiFi adapter not detected after low battery suspension Fedora 29
    check powertop and/or tlp settings for that adaptor
    Jan 2019
    Piedmont NC, USA
    4
    Linux Firefox 65.0
    Neither of those packages are installed, so no settings
    1,052
    Linux (Fedora) Firefox 64.0
    Can you add a new user to your system, cold boot it again, and log in as that different user ? and tell me if the WiFi device is found ?
    Jan 2019
    Piedmont NC, USA
    4
    Linux Firefox 65.0
    Thanks for getting back to me. I am sorry I did not post that I solved the problem.
    It looks like my most recent update failed on parts. I did another DNF update / upgrade and the problem went away. The reason I tried this route is I found that network manager was missing some components.
  1. BrosTrend ac1200 wifi adapter working in Fedora 29
    By Agent4514 in forum Hardware & Laptops
    Last Post: 10th November 2018, 07:21 PM
  2. Can't install fedora 23 because of wifi adapter.
    By Catman5 in forum Installation, Upgrades and Live Media
    Last Post: 10th March 2016, 05:15 PM
  3. WIFI adapter for Fedora. . .
    By Ecsit in forum Using Fedora
    Last Post: 26th July 2013, 12:24 AM
  4. LM Technologies WiFi USB Adapter work out of the box in Fedora 13!
    By lovenemesis in forum Servers & Networking
    Last Post: 17th March 2010, 05:13 PM
  5. Netgear WG111 wireless adapter not detected in Fedora Core 4
    By rishath in forum Hardware & Laptops
    Last Post: 27th August 2005, 09:00 PM
