Print Problem Epson XP-342 using WebBrowser
    Jan 2019
    Germany
    Linux (Fedora) Firefox 64.0
    Hi everyone,
    Ive got a problem using WebBrowsers (Chromium, Firefox).
    My Epson Printer (XP-342) is connected via Network (no usb).
    Printing with Software like Okular, Kate or Libre Office/Draw is no problem and works just fine.
    Printing with Firefox or Chromium gives me an arrow of Abbortion.
    I have no clue what i can do or where to look at efficiently to get the problem solved.
    Has anyone suggestions?
    Greetings 7ie7an
    Oct 2006
    CN99CF Agassiz BC Canada
    405
    Linux (Fedora) Firefox 60.0
    Re: Print Problem Epson XP-342 using WebBrowser
    Your printer, being a network connection based interface, may have simply timed out if your system has been up for any appreciable length of time.
    Try the following:
    In a fresh tab in Firefox, type localhost:631 in the address bar. This will bring up the CUPS interface to your printer. Go into Printers and select your printer, then print a test page (leftmost drop-down box).
    You will probably find that Firefox now works as the other programs on your system.
    I read your post and knowing that my system had been up stince 2018.12.25, I thought I would try printing from Firefox. I received an error message, then I followed the procedure described above and all started working.
    Good luck!
    Jan 2019
    Germany
    That worked Great
    Thank You
    Do I Always have to install it that way or did i do sth. wrong at the initial install process?
    Oct 2006
    405
    iOS  12.1.2 (iPhone) Safari 12.0
    Because your other programs were printing well through CUPS, it suggests that your installation was correct.
    Considering both of us had Firefox time out, it appears that Firefox incorrectly queries the printer status and reports an error.
  1. EPSON CX11NF won't print
    By wolfitc in forum Hardware & Laptops
    Last Post: 24th November 2017, 06:12 PM
  2. printer epson xp-322 won't print
    By thatmikewilliam in forum Hardware & Laptops
    Last Post: 9th November 2015, 07:46 PM
  3. impossible print with epson stylus c62
    By matbos in forum Hardware & Laptops
    Last Post: 25th February 2014, 03:21 PM
  4. Epson Workforce 435 spooling print jobs, but doesn't print
    By danlcarver in forum Hardware & Laptops
    Last Post: 4th August 2012, 09:48 PM
  5. Problem with Accessing localhost on webbrowser after installing LAMP :S
    By PoetGuy in forum Installation, Upgrades and Live Media
    Last Post: 2nd May 2009, 05:54 PM
