I have an up to date Fed 29 installation which is failing to mount by USB keys.
The same devices on my mobile running fed28 work as expected.
[529492.488945] usb 1-5: new high-speed USB device number 16 using ehci-pci
[529492.623211] usb 1-5: New USB device found, idVendor=0930, idProduct=6545, bcdDevice= 1.00
[529492.623221] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[529492.623227] usb 1-5: Product: USB Flash Memory
[529492.623233] usb 1-5: Manufacturer:
[529492.623239] usb 1-5: SerialNumber: xxxxxxxxxxxxxxxxxxxxxxxx
[529492.623950] usb-storage 1-5:1.0: USB Mass Storage device detected
[529492.630129] scsi host6: usb-storage 1-5:1.0
[529493.710541] scsi 6:0:0:0: Direct-Access              USB Flash Memory PMAP PQ: 0 ANSI: 4
[529493.712977] sd 6:0:0:0: Attached scsi generic sg4 type 0
[529494.949136] sd 6:0:0:0: [sdd] 15248832 512-byte logical blocks: (7.81 GB/7.27 GiB)
[529494.951290] sd 6:0:0:0: [sdd] Write Protect is off
[529494.951300] sd 6:0:0:0: [sdd] Mode Sense: 23 00 00 00
[529494.953484] sd 6:0:0:0: [sdd] No Caching mode page found
[529494.953493] sd 6:0:0:0: [sdd] Assuming drive cache: write through
[529494.985022]  sdd: sdd1
[529494.989338] sd 6:0:0:0: [sdd] Attached SCSI removable disk
So it is recognised and a device created in /dev however, nothing in /run/media and nothing showing in mount output for this device.
This is happening with several devices, so it is not this particular key which is bad.
If I mount it manually as root it seem fine.
why is automount broken?
BTW using LXDE spin.
