Upgrade fedora28 to 29 created logging out itself problem for GNOME
    Jul 2015
    Delhi
    5
    Linux (Fedora) Firefox 63.0
    everything was going fine , but unfortunately my system got power off abnormally in between update from fedora28 to 29 . now when i am opening my system the GNOME getting logout itself . meanwhile we are able to access my system in KDE Plasma and from this GUI i am trying to resolve the update issue but getting the following error , please help me out to resolve it so that we could update it to fedora 29 and might be able to access GNOME GUI .
    Traceback (most recent call last):
    File "/usr/bin/dnf", line 57, in <module>
    from dnf.cli import main
    File "/usr/lib/python3.7/site-packages/dnf/__init__.py", line 30, in <module>
    import dnf.base
    File "/usr/lib/python3.7/site-packages/dnf/base.py", line 31, in <module>
    from dnf.comps import CompsQuery
    File "/usr/lib/python3.7/site-packages/dnf/comps.py", line 27, in <module>
    from dnf.exceptions import CompsError
    File "/usr/lib/python3.7/site-packages/dnf/exceptions.py", line 22, in <module>
    import dnf.util
    File "/usr/lib/python3.7/site-packages/dnf/util.py", line 29, in <module>
    import dnf.callback
    File "/usr/lib/python3.7/site-packages/dnf/callback.py", line 22, in <module>
    import dnf.yum.rpmtrans
    File "/usr/lib/python3.7/site-packages/dnf/yum/rpmtrans.py", line 26, in <module>
    import rpm
    ModuleNotFoundError: No module named 'rpm'
    Dec 2014
    sd
    53
    Re: Upgrade fedora28 to 29 created logging out itself problem for GNOME
    Can you do ---sudo dnf groupinstall "GNOME Desktop Environment"---from the terminal (either via KDE or a Ctrl + Alt +F2)?
  1. Montage on Fedora28 - freetype/harfbuff problem
    By Skops in forum Using Fedora
    Last Post: 28th September 2018, 12:20 PM
  2. Problem logging in after upgrade
    By leonardevens in forum Using Fedora
    Last Post: 12th June 2014, 04:20 AM
  3. [SOLVED]
    sftp logging after upgrade from FC9 to FC14
    By dbnakuru in forum Servers & Networking
    Last Post: 25th May 2011, 12:56 AM
  4. How to set the gnome default theme when new user created?
    By mounterriver in forum Using Fedora
    Last Post: 9th June 2006, 02:41 AM
  5. Problem with gnome after logging in
    By elfreitas in forum Using Fedora
    Last Post: 26th October 2005, 01:12 PM
