[SOLVED] Help! Fedora upgrade failed to start. How to abandon upgrade?
    Apr 2014
    Home
    45
    Linux (Android 5.0.1) Chrome 69.0.3497.100
    I tried to upgrade from 25 to 27. I get the message the upgrade fails to start then my laptop goes into a reboot.
    I can get into the recovery boot or get to my files with a live CD.
    I am no longer interested in trying to fix the upgrade. I would like to stick to 25. How do I cancel the upgrade and get my system back? Surely there is something pointing at the upgrade that I can delete?
    Feb 2005
    London, UK
    771
    Windows 7 Chrome 69.0.3497.100
    Re: Help! Fedora upgrade failed to start. How to abandon upgrade?
    First things first, backup your files!
    Second, try selecting the older Kernel in the grub list, although that probably won't work.
    Then you could try a "dnf history list" to see a list of dnf transactions, get the ID of the update from the left column and then "dnf history rollback <ID>". However I'm not sure if it will work on a OS level upgrade.
    Lastly, and probably your best option is to reinstall from a live CD to make sure the system is clean. I assume all of your files are in a separate /home partition in which case it's just a matter of making sure you select not to format the /home partition when you select the disk layout.
    BTW, you should only upgrade one OS level at a time, so F25 -> F26 -> F27.
    Apr 2014
    Home
    45
    Solved the problem.
    Years ago, due to space problems on / I had moved dnf from /var/lib to /home and put a link. I moved dnf back to /var/lib.
    When I rebooted I was back in fedora 25. No more mention of the upgrade from fedora.
  1. DNF system upgrade failed during upgrade
    By pnelsonsr in forum Installation, Upgrades and Live Media
    Last Post: 8th May 2018, 02:55 AM
  2. "Failed to start Load Kernel Modules." after Fedup Upgrade
    By JackC in forum Installation, Upgrades and Live Media
    Last Post: 4th June 2015, 01:59 PM
  3. System Upgrade (fedup) to FC20 give do not start the upgrade
    By aend4ab in forum Installation, Upgrades and Live Media
    Last Post: 14th March 2014, 03:46 PM
  4. F16 boot Failed to Start LSB - 3.3 kernel upgrade?
    By iammik in forum Using Fedora
    Last Post: 11th November 2012, 09:58 PM
  5. PulseAudio daemon failed to start after HW upgrade
    By globe5 in forum Hardware & Laptops
    Last Post: 12th September 2012, 04:36 PM
