Resume=UUID=. Issue
    5,539
    Linux (Android 8.0.0) Chrome 69.0.3497.100
    Resume=UUID=. Issue
    I have a multi-disk system with F29 KDE spin on one disk and F29Gnome on another. Every other day I do a fresh install of the Gnome version to mark progress and to test code.
    When I reinstall F29 Gnome, it randomly selects a unused swap area for the resume=. But occasionally I just happen to delete that particular swap area, after the F29GNOME install as when doing a reformat, with UUID change for that swap partition.
    Consequences
    When I boot the F29GNOME system with unmatched UUID for resume, I experience a 1.5 min wait for a mount that will never occur.
    After I fix up the grub.cfg, things are not working onn the next reboot. Gnome will not run. It hangs . And on the next "warm" reboot, the boot messages indicate Microcode corruption, and I see that two of the quad core have corrupted microcode. It takes a system power off and a fresh cold reboot to resolve the microcode problem. Still, F29GNOME will not initiate. The session is fully dead.
    From the command line I can run "startx" and run gnome.
    Any Ideas what to look for to resolve this problem. I modified /etc/default/grub and grub.cfg to point to a protected swap partition before first use of F29GNOME.
    Corrupting microcode should never happen. How to debug/resolve?
    5,539
    Linux (Fedora) Firefox 62.0
    Re: Resume=UUID=. Issue
    Still a problem for F29
    BUG 1489554 gnome btrfs bug again. (low priority)
    Bug 1583863 Release Notes
    Bug 1590489 - Kernel 4.18 usb printer can't be installed.
    Bug 1598403 tracking of strip issue
    Bug 1621922 F29 install failure with txtfonts. dnf crashes and crashes anaconda
    Bug 1631923 Truncated image. (anaconda images are larger than the assigned window)
    Bug 1632799 /etc/default/grub resume If resume swap file disappears major problems
    Bug 1633786 boltd and Selinux
  1. Boot issue after suspend/resume failure
    By rbattenfeld in forum Using Fedora
    Last Post: 6th July 2014, 05:45 PM
  2. Fedora 16 Thinkpad X40 resume from hibernation issue
    By TiberiusisGame in forum Hardware & Laptops
    Last Post: 20th June 2012, 03:47 PM
  3. uuid issue?
    By Jongi in forum Using Fedora
    Last Post: 27th November 2009, 09:15 PM
  4. Laptop Suspend/Resume Issue
    By progrock in forum Hardware & Laptops
    Last Post: 10th June 2008, 08:55 PM
  5. Suspend/resume issue FC6 + Thinkpad
    By icantux in forum Hardware & Laptops
    Last Post: 24th February 2007, 01:19 AM
