partion latout for ssd and 5tb drive
    Sep 2018
    columbus/Oh
    Linux (Ubuntu) Firefox 62.0
    This is 2 part question on my hard drive settings Here my computer spec I have a i5-6 Intel with 23 g of ram
    1st question since I have 23g of ram do I need a swap part ?
    2nd since I have a 1 tb SSD and a 5tb drive if I want to use most of the SSD for fedora what partion layout should I use
    6,390
    Linux Chrome 69.0.3497.100
    Re: partion latout for ssd and 5tb drive
    a swap partition is not necessarily needed with that much RAM. you can always create a small swap file if you find any programs won't run without a swap present, they really are few and far between these days though.
    there is no real recommended scheme to suit all users but if you aren't sure what to do then refer to these instructions:
    https://docs.fedoraproject.org/en-US...commended.html
    5,402
    Unknown Firefox 62.0
    If using modern Linux distributions, you should reserve a swap partition of about 8 gigs for the resume function. Once you define the swap partition, put its value into the /etc/default/grub. Once you do that grub file update, run
    sudo grub2-mkconfig.
    The resume info from the grub file will be transferred to the grub.cfg file.
    Sep 2018
    columbus/Oh
    Linux (Fedora) Firefox 62.0
    thanks for all the help I did a 8g par.
  1. Partion after installation
    By Ujjwol in forum Installation, Upgrades and Live Media
    Last Post: 4th February 2008, 03:28 AM
  2. Use NTFS partion on FC5
    By weapon-x in forum EOL (End Of Life) Versions
    Last Post: 2nd August 2006, 01:05 PM
  3. Linux hdd partion
    By CassTreat in forum Hardware & Laptops
    Last Post: 24th October 2004, 08:17 AM
  4. mounting hard drive partion
    By firstc520 in forum Using Fedora
    Last Post: 30th May 2004, 05:18 PM
