How to burn ISO to USB?
Results 1 to 9 of 9
    Sep 2018
    Athens-Rome alternate every 3 days
    41
    Linux (Fedora) Firefox 62.0
    I have an ISO image that I would like to burn to a USB and make it bootable. How would I go about doing that?
    I did it on WIndows for Fedora, kept the ISO, but got rid of Windose. How can I make another bootable USB from Fedora?
    5,415
    Re: How to burn ISO to USB?
    I created the following script ( mydd.sh ) which puts a wrapper around the dd utility.
    #!/bin/bash
    USB='/dev/sdf'             #set to your default usb drive, mine is /dev/sdf, yours might be /dev/sdb
    if [[ $# -eq 0  ||  $# -gt 2 ]];
    then
       echo  "Use to create Bootable USB. Us as: $(basename $0) Path_to_Linux.iso [/dev/sd?]"
       echo "$(basename $0) path_to_iso/isofile.iso [optional /dev/sdn? ]"
       echo "Default is to /dev/sdf, however user parameter 2 to override "$USB""
       echo "   You must be certain that the /dev/sd? is for a flashdrive]"
       echo "   If in doubt, use sudo lsblk or gparted"
       exit 1
    fi
    if [ $# -eq 2 ];
    then
       USB=$2
        rc=$(echo "$USB" | /usr/bin/grep -c "/dev/sd")
        echo "Echo rc=$rc"
    #   [ $rc == 1 ] || echo "Wrong flash drive id" && exit 1
    fi
    echo "sudo dd if=$1 of=$USB   bs=8M status=progress oflag=direct,sync"
    Want the minimum then do it manually as:
    sudo dd if=inputfile of=output_device, bs=8M && sync
    May 2005
    26
    Quote Originally Posted by Feromi
    You might want to try Fedora Media Writer, open a terminal then,, " sudo dnf install mediawriter "
    It's in the repositories, works very well even with alternate distributions live media.
    Easy to use with graphic interface.
    (It's a hobby, but I like it)
    Aug 2009
    In a cardboard box
    2,103
    Linux (Ubuntu) Firefox 62.0
    Or Etcher, from the repo...
    https://github.com/resin-io/etcher
    I used to miss my wife but then my aim improved.
    Apr 2018
    Finland
    101
    Linux (Fedora) Chrome 69.0.3497.92
    Iso Image Writer also does the job and can be found from default repos. I used software center to install it so I don't know it's exact name.
    Ventura, CA
    427
    Many use dd to burn isos to a usb device. Here is the command: sudo dd if=/path/to/Fedora.iso of=/dev/sdX bs=4M. The path /dev/sdX should be the path to your USB device. Make sure that this path is correct (use "sudo fdisk -l" to check for paths to your devices), otherwise you could end up harming your data or even your system.
    In the past I have had problems with Fedora Image Writer.
    Here is the Fedora wiki for burning isos to a usb device: https://docs.fedoraproject.org/en-US...age/index.html
    I see Isatenstein has already mentioned dd; sorry for the duplication.
    Mar 2004
    In your closet
    15,724
    Linux Chrome 69.0.3497.100
    I just wrote the F29 LXDE Beta ISO to a thumb drive using dd. Be extremely careful with the destination or you'll overwrite something important. The command lsblk told me that the thumb drive is /dev/sdf
    PHP Code:
    sudo dd if=/mnt/iso/linux/Fedora/29/Fedora-LXDE-Live-x86_64-29_Beta/Fedora-LXDE-Live-x86_64-29_Beta-1.5.iso of=/dev/sdf bs=4M status=progress;sync
    Glenn
    The Bassinator
    Jul 2017
    mashhad
    8
    It should be better
    sudo dd if=file.iso of=/dev/sdb bs=1M;sudo sync;sudo eject /dev/sdb
    6,390
    Linux Firefox 62.0
    you don't need to repeat sudo three times in one command string, the first sudo covers the lot
  1. cant burn a 8Gb dvd.. :(
    By FedoraSuperFan in forum Using Fedora
    Last Post: 17th March 2008, 05:11 PM
  2. Cant burn 8gb DVD :(
    By FedoraSuperFan in forum Hardware & Laptops
    Last Post: 19th December 2007, 07:10 PM
  3. FC3 cannot burn DVD+R
    By tsangcn in forum Using Fedora
    Last Post: 7th February 2007, 03:42 AM
  4. Can not burn DVD's
    By ruffieux in forum Using Fedora
    Last Post: 25th March 2005, 01:46 AM
