I could not connect to a specific wifi network
Results 1 to 6 of 6
    Sep 2018
    Nepal
    3
    Linux (Fedora) Firefox 62.0
    Question I could not connect to a specific wifi network
    I am using fedora 28 and I was trying to connect to a wifi network with SSID "rajatopperkada" but I could not connect to it.
    But I can connect to the wifi network with another SSID
    I used network manager as well as wpa_supplicant.
    wpa_supplicant shows!!!
    <3>CTRL-EVENT-SSID-REENABLED id=0 ssid="rajatopperkada"
    <3>SME: Trying to authenticate with 84:79:73:e9:26:9a (SSID='rajatopperkada' freq=2412 MHz)
    <3>Trying to associate with 84:79:73:e9:26:9a (SSID='rajatopperkada' freq=2412 MHz)
    <3>Associated with 84:79:73:e9:26:9a
    <3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
    <3>CTRL-EVENT-DISCONNECTED bssid=84:79:73:e9:26:9a reason=3 locally_generated=1
    <3>CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="rajatopperkada" auth_failures=3 duration=46 reason=CONN_FAILED
    <3>CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
    <3>CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=DE
    My wpa_supplicant is
    ctrl_interface=/var/run/wpa_supplicant
    ctrl_interface_group=wheel
    network={
    #psk="something secret"
    psk=da3a7f4c859f7eda5361d1aef57d4aa0b292af6611eea3 ba065a945ab33a496c
    Thank you in advance!!
    6,398
    Linux Chrome 69.0.3497.100
    Re: I could not connect to a specific wifi network
    what wifi adaptor are you using? please post the wireless adaptor model and driver in use
    https://forums.fedoraforum.org/showt...kmark-it-first
    Sep 2018
    Nepal
    3
    Linux (Android 7.0) Chrome 69.0.3497.100
    I am using,
    Realtek RTL8723BE PCIe Wireless Network adaptor
    driver: rtl8723be
    6,398
    therein lies the rub. unfortunately that adaptor chip is notoriously problematic with all linux distributions. try this though.
    Sep 2018
    Nepal
    3
    I tried the method, but didn't help.
    6,398
    Quote Originally Posted by Samip
    consider replacing the card then if you can access it with an intel or atheros. alternatively a USB dongle but USB devices can also be problematic if you pick the wrong one.
  1. Specific WiFi network not found
    By StarmanF in forum Servers & Networking
    Last Post: 27th April 2018, 09:34 AM
  2. Replies: 6
    Last Post: 13th April 2014, 04:51 AM
  3. Replies: 44
    Last Post: 12th December 2011, 08:42 PM
  4. Replies: 11
    Last Post: 22nd March 2008, 11:04 AM
  5. FC6 Firewall, allow only specific hosts to connect to port 25
    By studerje in forum Servers & Networking
    Last Post: 28th November 2006, 11:02 PM
