dnf problem after upgrade in place to fedora 29 pre beta
Results 1 to 11 of 11
    Jul 2013
    NZ
    434
    Linux (Fedora) Firefox 62.0
    dnf crashes with seg fault after upgrading. I followed the workaround in the rawhide bug below and the problem is solved.
    https://bugzilla.redhat.com/show_bug.cgi?id=1600917
    Oct 2011
    1,863
    Linux Chrome 68.0.3440.106
    Re: dnf problem after upgrade in place to fedora 29 pre beta
    Jul 2013
    NZ
    434
    If I'm reading it right then this bug has been accepted as a Beta release blocker so I assume that means it will be getting attention. At least there is an easy workaround.
    Oct 2005
    Puerto Rico
    594
    Hi, after upgrading to F29 I'm getting some errors from dnf:
    Last metadata expiration check: 0:00:53 ago on Wed 26 Sep 2018 08:39:43 AM EDT.
    Dependencies resolved.
     Problem 1: cannot install the best update candidate for package bubblewrap-0.3.0-2.fc29.x86_64
      - package bubblewrap-0.3.0-2.module_2123+73a9ef6f.x86_64 is excluded
     Problem 2: cannot install the best update candidate for package eog-3.28.3-1.fc29.x86_64
      - package eog-3.28.3-1.module_2123+73a9ef6f.x86_64 is excluded
     Problem 3: cannot install the best update candidate for package exempi-2.4.5-3.fc29.x86_64
      - package exempi-2.4.5-3.module_2123+73a9ef6f.x86_64 is excluded
     Problem 4: cannot install the best update candidate for package libnghttp2-1.33.0-1.fc29.x86_64
      - package libnghttp2-1.33.0-1.module_2177+2526c218.x86_64 is excluded
     Problem 5: cannot install the best update candidate for package libpeas-1.22.0-9.fc29.x86_64
      - package libpeas-1.22.0-9.module_2123+73a9ef6f.x86_64 is excluded
     Problem 6: cannot install the best update candidate for package libpeas-gtk-1.22.0-9.fc29.x86_64
      - package libpeas-gtk-1.22.0-9.module_2123+73a9ef6f.x86_64 is excluded
     Problem 7: cannot install the best update candidate for package libpeas-loader-python3-1.22.0-9.fc29.x86_64
      - package libpeas-loader-python3-1.22.0-9.module_2123+73a9ef6f.x86_64 is excluded
     Problem 8: cannot install the best update candidate for package perl-HTTP-Tiny-0.076-1.fc29.noarch
      - package perl-HTTP-Tiny-0.076-1.module_2073+eebc5b71.noarch is excluded
     Problem 9: cannot install the best update candidate for package perl-Thread-Queue-3.13-1.fc29.noarch
      - package perl-Thread-Queue-3.13-1.module_2073+eebc5b71.noarch is excluded
    Nothing to do.
    Complete!
    Would this be related to this bug? I searched bugzilla but found nothing to the point.
    5,402
    Linux Firefox 61.0
    Quote Originally Posted by Boricua
    Nothing to do.
    Complete!
    try this first
    sudo dnf update bubblewrap --skip --allow --best
    If that does not work, then
    sudo dnf remove bubblewrap*
    sudo dnf install bubblewrap*
    I am not sure that you can use dnf reinstall bubblewrap*
    Oct 2005
    Puerto Rico
    594
    Thanks for your quick response. Unfortunately, it didn't work. Here's what I got:
    [francisco@main ~]$ sudo dnf update bubblewrap --skip --allow --best
    [sudo] password for francisco:
    Copr repo for telegram owned by rommon          214  B/s | 345  B     00:01
    Failed to synchronize cache for repo 'rommon-telegram', ignoring this repo.
    Last metadata expiration check: 0:36:47 ago on Wed 26 Sep 2018 08:39:43 AM EDT.
    Nothing to do.
    Complete!
    [francisco@main ~]$ sudo dnf remove bubblewrap*
     Package                                Arch    Version          Repository
        Size
    Removing:
     bubblewrap                             x86_64  0.3.0-2.fc29     @System   91 k
    Removing dependent packages:
     cheese                                 x86_64  2:3.30.0-2.fc29  @System  438 k
     cheese-libs                            x86_64  2:3.30.0-2.fc29  @System  2.3 M
     chrome-gnome-shell                     x86_64  10.1-3.fc29      @System   61 k
     eog                                    x86_64  3.28.3-1.fc29    @System   10 M
     evince                                 x86_64  3.30.0-2.fc29    @System  9.2 M
     evince-nautilus                        x86_64  3.30.0-2.fc29    @System   23 k
     evolution                              x86_64  3.30.0-1.fc29    @System   15 M
     evolution-ews                          x86_64  3.30.0-1.fc29    @System  1.3 M
     evolution-ews-langpacks                noarch  3.30.0-1.fc29    @System  910 k
     evolution-help                         noarch  3.30.0-1.fc29    @System   13 M
     evolution-langpacks                    noarch  3.30.0-1.fc29    @System   35 M
     flatpak                                x86_64  1.0.2-1.fc29     @System  4.0 M
     flatpak-libs                           x86_64  1.0.2-1.fc29     @System  911 k
     fwupd                                  x86_64  1.1.2-1.fc29     @System  4.5 M
     gdm                                    x86_64  1:3.30.0-3.fc29  @System  2.3 M
     gnome-clocks                           x86_64  3.30.0-3.fc29    @System  1.4 M
     gnome-contacts                         x86_64  3.30-1.fc29      @System  1.6 M
     gnome-control-center                   x86_64  3.30.0-1.fc29    @System   20 M
     gnome-desktop3                         x86_64  3.30.0-2.fc29    @System  2.6 M
     gnome-documents                        x86_64  3.30.0-1.fc29    @System  2.2 M
     gnome-documents-libs                   x86_64  3.30.0-1.fc29    @System  1.4 M
     gnome-font-viewer                      x86_64  3.30.0-1.fc29    @System  731 k
     gnome-initial-setup                    x86_64  3.29.92-1.fc29   @System  2.6 M
     gnome-photos                           x86_64  3.30.0-1.fc29    @System  4.8 M
     gnome-session                          x86_64  3.30.0-1.fc29    @System  1.5 M
     gnome-session-wayland-session          x86_64  3.30.0-1.fc29    @System  7.4 k
     gnome-session-xsession                 x86_64  3.30.0-1.fc29    @System   15 k
     gnome-settings-daemon                  x86_64  3.30.0-1.fc29    @System  5.2 M
     gnome-shell                            x86_64  3.30.0-8.fc29    @System  7.3 M
     gnome-shell-extension-background-logo  noarch  3.24.0-6.fc29    @System   58 k
     gnome-shell-extension-common           noarch  3.30.0-1.fc29    @System  593 k
     gnome-shell-extension-user-theme       noarch  3.30.0-1.fc29    @System  6.8 k
     gnome-software                         x86_64  3.30.0-1.fc29    @System  9.1 M
     gnome-tweaks                           noarch  3.30.0-1.fc29    @System  1.4 M
     mutter                                 x86_64  3.30.0-1.fc29    @System   12 M
     pitivi                                 x86_64  0.99-4.fc29      @System  9.2 M
     python2-notify                         x86_64  0.1.1-36.fc28    @System   73 k
     totem                                  x86_64  1:3.26.2-1.fc29  @System  7.7 M
     totem-nautilus                         x86_64  1:3.26.2-1.fc29  @System   40 k
     xdg-desktop-portal                     x86_64  1.0.2-1.fc29     @System  1.5 M
     xdg-desktop-portal-gtk                 x86_64  1.0.2-1.fc29     @System  725 k
    Transaction Summary
    Remove  42 Packages
    Freed space: 192 M
    Is this ok [y/N]:
    Operation aborted.
    [francisco@main ~]$ sudo dnf reinstall bubblewrap*
    Last metadata expiration check: 0:37:54 ago on Wed 26 Sep 2018 08:39:43 AM EDT.
     Package            Arch           Version                 Repository      Size
    Reinstalling:
     bubblewrap         x86_64         0.3.0-2.fc29            fedora          46 k
    Transaction Summary
    Total download size: 46 k
    Installed size: 91 k
    Is this ok [y/N]: y
    Downloading Packages:
    bubblewrap-0.3.0-2.fc29.x86_64.rpm               31 kB/s |  46 kB     00:01
    Total                                            14 kB/s |  46 kB     00:03
    Running transaction check
    Transaction check succeeded.
    Running transaction test
    Transaction test succeeded.
    Running transaction
      Preparing        :                                                        1/1
      Reinstalling     : bubblewrap-0.3.0-2.fc29.x86_64                         1/2
      Cleanup          : bubblewrap-0.3.0-2.fc29.x86_64                         2/2
      Running scriptlet: bubblewrap-0.3.0-2.fc29.x86_64                         2/2
      Verifying        : bubblewrap-0.3.0-2.fc29.x86_64                         1/2
      Verifying        : bubblewrap-0.3.0-2.fc29.x86_64                         2/2
    Reinstalled:
    Complete!
    Copr repo for telegram owned by rommon          211  B/s | 345  B     00:01
    Last metadata expiration check: 0:38:14 ago on Wed 26 Sep 2018 08:39:43 AM EDT.
    Nothing to do.
    Complete!
    It looks that the only option would be to uninstall bubblewrap with all its dependencies , and then install.
    Apr 2005
    Owatonna, Minnesota
    139
    Linux Firefox 56.2.3
    This is not a recommended procedure, but it's one I've used when faced with similar situations. My first step is to download a copy of the currently installed version package I'm going to delete. Then I use rpm -e --nodeps to remove the package I want to upgrade. Then I install the upgrade, using either dnf (if no additional packages are going to be removed) or rpm. Again, this is not recommended and can definitely lead to a broken system (I speak from experience!). YMMV
    RockDoctor
    Registered Linux user #360200
    Oct 2005
    Puerto Rico
    594
    I actually uninstalled bubblewrap with all its dependencies and then reinstalled most of them, except for the following which I don't really needed:
    cheese-2:3.30.0-2.fc29.x86_64
      evolution-help-3.30.0-1.fc29.noarch
      gnome-clocks-3.30.0-3.fc29.x86_64
      gnome-contacts-3.30-1.fc29.x86_64
      gnome-documents-3.30.0-1.fc29.x86_64
      gnome-documents-libs-3.30.0-1.fc29.x86_64
      gnome-font-viewer-3.30.0-1.fc29.x86_64
      gnome-initial-setup-3.29.92-1.fc29.x86_64
      gnome-photos-3.30.0-1.fc29.x86_64
      gnome-shell-extension-background-logo-3.24.0-6.fc29.noarch
      python2-notify-0.1.1-36.fc28.x86_64
      totem-1:3.26.2-1.fc29.x86_64
      totem-nautilus-1:3.26.2-1.fc29.x86_64
    Then, I ran dnf clean all and dnf update, and got the same result
    Oct 2005
    Puerto Rico
    594
    Quote Originally Posted by rockdoctor
    Hmmm... I will consider your solution, which makes perfect sense, but considering the odds I will wait for a while to see what future updates bring, before trying it.
    Oct 2011
    1,863
    No, do not use --nodeps. --nodeps is useful in some cases, but not in this one. Also this has nothing to do with the original bug. See the devel mailing list thread for clues: https://www.spinics.net/lists/fedora...msg248008.html, https://www.spinics.net/lists/fedora...msg248031.html
    Oct 2005
    Puerto Rico
    594
    Quote Originally Posted by srakitnican
    Yep, definitely not the same bug. Sorry for invading this thread. I subscribed to the bug reports in bugzilla. From what I saw, dnf will still be able to updates packages, notwithstanding the alarming messages.
  1. Upgrade Fedora 26 > 27 Beta?
    By fossiili in forum F27 Development Forum
    Last Post: 7th November 2017, 11:45 AM
  2. Want to test the beta (upgrade Fedora 22)
    By lsatenstein in forum F23 Development Forum
    Last Post: 5th October 2015, 08:30 PM
  3. Question about in place upgrade from f19-> f20
    By alphacrucis in forum F-20 Development Forum
    Last Post: 27th October 2013, 11:02 AM
  4. upgrade to Fedora 13 Beta
    By irvy in forum Fedora 13 Development Branch
    Last Post: 10th May 2010, 11:05 AM
