Custome ISO for RHEL7.5 fails to install
    Aug 2008
    36
    8
    Mac OS X 10.13 Firefox 62.0
    Hello Everyone,
    I understand this is Fedora forum and not RHEL, but in hope of getting an answer from someone more experienced, I'm asking.
    I have created a custom ISO for RHEL7.5 with few new RPMS. recreated repodata and build ISO.
    I used following command for build ISO
    genisoimage  -o ../iso/cstm-$(iso_for_version).iso -b isolinux/isolinux.bin \
                            -c isolinux/boot.cat  -no-emul-boot -boot-load-size 4 \
                            -boot-info-table -l -J -r -V "CSTM 7.5" -volset "CSTM 7.5" -A "CSTM 7.5" . ; \
    I'm also using Kickstart file to install the OS and do few settings automatically.
    Install is called using
    label CSTM2
      menu label ^even CSTM Server Install(CSTM2)
      menu default
      kernel vmlinuz
      append initrd=initrd.img text inst.stage2=hd:LABEL=CSTM\x207.5 inst.ks=cdrom:/dev/cdrom:/cstm2.ks.cfg net.ifnames=0 biosdevname=0
    During the installation process, everything works fine till it starts installing RPM packages.
    5th package is filesystem (5/769)
    and then it errors out saing
    RepoError, retrying: Insufficient space in download directory /run/install/repo/Packages
    This particular directory in question is /mnt/sr0, so naturally it won't have any space.
    I'm stumped as to what am I doing wrong? Does anyone else have any idea?
    Harry
    Dec 2017
    65
    Windows 7 Firefox 61.0
    Re: Custome ISO for RHEL7.5 fails to install
    Perhaps the directory used for extraction/downloading can be a tmpfs or mounted from the local storage (hdd/ssd)? Not entirely sure how that would work in a kickstart/ISO.
    Feb 2009
    The Netherlands
    24
    Linux Chrome 65.0.3325.230
    Quote Originally Posted by bgstack15
    Seems Harry points in the right direction :>) Personally, I don't have an answer right away.
    Could it be that some package is needed to install the ISO? (probably not)
    YUM or DNF conflict?
  1. F11 - graphical install fails - text install has no fdisk
    By redstar427 in forum Installation, Upgrades and Live Media
    Last Post: 2nd July 2009, 06:13 AM
  2. Finding the size of a custome class type in java
    By cola in forum Programming & Packaging
    Last Post: 18th February 2009, 12:05 AM
  3. Fedora 10 default install fails with ATI 4850 graphics card (but text install works)
    By Jeff72 in forum Installation, Upgrades and Live Media
    Last Post: 20th January 2009, 06:27 PM
