Virtual Box
Results 1 to 8 of 8
    Sep 2018
    a house
    Linux (Fedora) Firefox 62.0
    Virtual Box
    You recently provided updates that required VirtualBox server files. That was corrected in a few days.
    I updated to 4-18-5 kernel and of course it ****ed up Virtual Box.
    Now, I have to use the previous kernel release.
    I used the Videos app in Fedora 27 and it worked fine. But you ****ed it up in Fedora 28.
    You're ****ing up more than you're fixing.
    Apr 2009
    central NY, USA
    1,152
    Linux (Fedora) Firefox 60.0
    Re: Virtual Box
    That will happen every time there is a kernel change as it needs to be rebuilt with the new kernel. One solution to this is to use the virtualbox repo rather than individually downloading the standalone file and manually installing (building) it.
    The "you" that are here on the forum are just users like you & me - not the Fedora developers. We're all just tying to help each other out when we get stuck.
    Change - the only constant.
    Dec 2011
    12
    Re: Virtual Box
    Well, I'm also having issues. I'm using from the repo. Well, from RepoForge... not from Oracle's incomplete repo that doesn't include things like VirtualBox Server.
    It seems there is a patch being applied when akmods is run... a patch that apparently shouldn't be. It looks like the effect of the patch is to apply the changes to utils.c that were applied in the Debian/Ubuntu version to fix 4.18.x compatibility. However, that is breaking things on Fedora 28.
    Dec 2011
    12
    Re: Virtual Box
    For what it's worth, I just tried it using the "official" Oracle repo, and that install is broken as well. In a similar manner (problems building the kernel modules). Yes, I am using secure boot. Yes, I did sign the kernel modules under both the Oracle version and under the RepoForge version. RepoForge is much closer to working IMO... just needs that autopatching stopped when running akmods... that or the patch corrected to actually work.
    Apr 2009
    central NY, USA
    1,152
    Linux Firefox 60.0
    Re: Virtual Box
    I had to (in my CentOS) turn OFF secure boot to get my VirtualBox update to build/install. It failed repeatedly before that. I don't remember, but I think I was able to turn secure boot back on afterwards.
    - just a thought. VirtualBox has certainly changed something ...
    Dec 2011
    12
    Mac OS X 10.13 Firefox 62.0
    Re: Virtual Box
    Quote Originally Posted by lightman47
    You just need to sign the driver modules for it to work w/out disabling secure boot. That isn't my problem, as I mentioned in my post: I've signed my modules and had no issues.
    For now I've reverted to kernel 4.16, and once I signed my driver modules all works correctly. This is 100% due to a faulty patch being applied by the VirtualBox kmod shipped from RepoForge.
    Apr 2009
    central NY, USA
    1,152
    Linux Firefox 60.0
    Re: Virtual Box
    How does one 'sign driver modules'?
    Dec 2011
    12
    Re: Virtual Box
    I used these instructions, or something very like them
    https://gist.github.com/gabrieljcs/6...6b40100130270d
  1. Virtual Caliper measuring virtual things.
    By BugRocks1 in forum Wibble
    Last Post: 6th July 2010, 05:38 AM
  2. Replies: 0
    Last Post: 2nd July 2009, 01:19 PM
  3. Mail Server with Virtual Host and Virtual Domains
    By ssdude in forum Servers & Networking
    Last Post: 2nd May 2009, 03:45 PM
  4. Sendmail: Virtual Hosts & Virtual Users
    By ridetehpenguin in forum Servers & Networking
    Last Post: 2nd June 2008, 07:57 PM
  5. Replies: 3
    Last Post: 3rd June 2007, 01:51 AM
