Slow transfer & errors from data DVD to solid state hard drive
    Jan 2011
    16
    Linux Firefox 45.0
    I've discovered a couple of odd problems doing a bulk transfer
    (using cp) of the contents of a data DVD to
    the (solid state) hard drive of my new 64-bit system.
    First, it takes a long time -- many seconds per 100 MB. Second, I got
    some "error reading" occurrences. After the bulk copy was done
    I verified that the data on the DVD are good, and I could do
    an individual cp on each failed file successfully. The DVD was
    made on my F12 system using the data DVD option of k3b. I could
    not learn online how to mount a data DVD on recent Fedora, but it
    turned out that my old alias for mounting a CDROM (mount -t iso9660)
    worked, so I used it. Please advise.
    Jul 2010
    western PA
    157
    Linux (Fedora) Firefox 60.0
    Re: Slow transfer & errors from data DVD to solid state hard drive
    writing flash devices is slow. You just don't notice it because when only writing a few files the IO is cached and the kernel finishes the job after the command prompt returns.
    use dd to copy the cdrom to an ISO image on the main hard disk, then mount the ISO image using the loop device and copy from it to the flash disk.
    another source of slowdown is if the cdrom and flash disk are both on the USB channel.
    6,294
    Linux Chrome 69.0.3497.81
    did you read the post tempest? there's no usb devices involved here. they are copying from DVD to an internal SSD
    @cpacker - check the cables are connected properly for both the optical drive and the SSD.
    Jul 2010
    western PA
    157
    my bad....sorry....either too much beer, or not enough while reading.
    So after reading it seems much more like just a hellofalot of IO errors on the DVD media he's trying to access then, or possibly a VERY FRAGMENTED image where there is much seeking going on on the DVD....which makes me wonder if the DVD was multi-session.
  1. Booting from a Solid State Drive ... WOW
    By rclark in forum Linux Chat
    Last Post: 28th August 2012, 09:09 PM
  2. New Intel solid-state drive hits 600GB
    By diamond_ramsey in forum Wibble
    Last Post: 29th March 2011, 05:25 PM
  3. ssd - solid state drive - as tmp drive
    By jimbux in forum Using Fedora
    Last Post: 10th February 2010, 03:43 AM
  4. Install Fedora on Solid-state drive
    By Milena in forum Hardware & Laptops
    Last Post: 11th November 2009, 09:47 PM
  5. USB Hard Drive - Slow transfer speeds w/FC5
    By vifa84 in forum Using Fedora
    Last Post: 2nd March 2007, 12:09 PM
