Is there a way to find out who or what is changing the balance of audio to left?
Results 1 to 15 of 17
    Dec 2015
    India
    189
    I'm using Fedora 28 Gnome.
    Jul 2004
    Colton, NY; Junction of Heaven & Earth (also Routes 56 & 68).
    74
    23,804
    Re: Is there a way to find out who or what is changing the balance of audio to left?
    Have you gone into your Settings and tried playing with the balance? Members might need some more information on whether this has been constant or a new issue, what your sound system is, etc.
    Registered Linux User #362651
    6,165
    1 Post(s)
    At the very low level, the command to adjust the sound is called amixer.
    To find out more, do "man amixer" or "info amixer".
    Dec 2015
    India
    189
    Quote Originally Posted by bob
    Thank you both for your helpful replies.
    I'm using Logitech Z333 2.1 speaker system, it connects to the computer through an analog 3.5mm jack.
    This change in audio balance towards the left channel has happened at least few times in recent weeks. Especially after I complained to a customer support of an earphone company that their product is producing less sound in left earphone. At least to my knowledge I haven't changed the audio balance settings. So I was wondering if someone was hacking and messing the audio balance settings and if it would be logged somewhere.
    I have a Realtek on-board sound card.
    Thanks
    Dec 2015
    India
    189
    This problem is back again. This time it is the complete opposite, the sound on the left side is low. It seems like the people who are doing this are modifying the config files and setting the left side to either more or less and setting it to read only, so the next time I reboot and log in, the skewed audio balance resumes.
    What config files determine the audio balance.
    Last edited by antikythera; 11th April 2019 at 10:10 AM. Reason: inappropriate language
    7,156
    6 Post(s)
    1 Thread(s)
    as frustrating as the issue may be please do not use inappropriate language on this forum
    Feb 2009
    132
    Did you try different speakers/headphones to eliminate hardware problems?
    6,165
    1 Post(s)
    amixer is what you would use to set the volumes for each channel. Did you do man amixer to read what it can do for you?
    May 2010
    Midwest USA
    52
    531
    1 Post(s)
    since modern Fedora uses pulseaudio, use pavucontrol if necessary lock the channels together. Only use amixer as a last resort.
    Running Fedora 30 64-bit on a HP EliteDesk 800 G1, 3.6GHz i7-4790 CPU (4 cores, 8 threads), 32GB RAM, 250GB SSD + 2TB HDD, EVGA GTX1050 TI SC 4GB GDDR5 video card. Vizio E221-A1 22" 1080p HDTV, using 1080P (1920x1080) over HDMI
    6,165
    1 Post(s)
    On my previous desktop I was able to use amixer to have both rear speaker jacks and front earphone jacks working concurrently, and I used amixer for balancing headphones.
    On my current system, the headphone jack now locks out the rear speaker jacks. It was great to be able to have both functioning.
    Dec 2015
    India
    189
    This problem has turned strange. Now midrange-treble are coming out of right side only, the left side is only producing bass-midrange.
    What software will allow me to set this right?
    New York state in USA
    257
    I ran into this mysterious change in balance during Rawhide (f30) testing. I was using the Gnome-Control-Center -> Sound tab controls in my testing. The problem turned out to be my casual mouse usage. If the mouse cursor is in the middle portion of the tab and you scroll up or down when the mouse cursor crosses the balance control, the balance control will scroll until is reaches it's limit. The scroll will continue in the direction (up or down) that was is process before the unhappy change to balance. If you keep you mouse cursor to either the right or left edge as you scroll this doesn't happen.
    I hope this helps.
    Have a Great Day!
    Dec 2015
    India
    189
    Quote Originally Posted by TablePC
    I hope this helps.
    That is the not case here. I'm not using GNOME. I have pavucontrol but it is unlikely to be effected by my casual usage of my mouse.
    Oct 2005
    Puerto Rico
    600
    And I believed my almost new Logitech speakers were to blame... I just starting having this issue with F30 Gnome. Left speaker works fine; no sound from right speaker at all. I checked sound configuration without success. Everything seems OK. I will try to unplug and try from another source.
    Dec 2015
    India
    189
    Quote Originally Posted by Boricua
    GNOME has a volume manager which allows the audio balance to be changed. See if it is skewed to either side.
  1. Audio problems with F12 after changing user
    By joe.pelayo in forum Using Fedora
    Last Post: 17th April 2010, 05:19 PM
  2. Changing mouse-button from left to right w. LXDE
    By Gul Dukat in forum Using Fedora
    Last Post: 18th January 2009, 02:01 PM
  3. Audio players not changing tracks
    By royeo in forum Using Fedora
    Last Post: 26th August 2006, 09:22 PM
  4. Changing the frame rate of an audio file?
    By lcapriotti in forum Using Fedora
    Last Post: 25th May 2005, 02:31 PM
