Unusual upgrade problem?
Results 1 to 13 of 13
    Feb 2013
    England
    369
    Linux (Fedora) Firefox 57.0
    I have been trying to upgrade fedora however it gives me the following output after downloading all the packages:
    Total 1.6 MB/s | 1.8 GB 18:20
    warning: /var/lib/dnf/system-upgrade/libde265-1.0.2-8.fc28.i686.rpm: Header V4 RSA/SHA1 Signature, key ID 09eab3f2: NOKEY
    Curl error (37): Couldn't read a file:// file for file:///etc/pki/rpm-gpg/RPM-GPG-KEY-rpmfusion-free-fedora-28 [Couldn't open file /etc/pki/rpm-gpg/RPM-GPG-KEY-rpmfusion-free-fedora-28]
    The downloaded packages were saved in cache until the next successful transaction.
    You can remove cached packages by executing 'dnf clean packages'.
    I went to their site downloaded the key for rpm fusion free and non free, and put into the folder etc/pki/rpm-gpg/
    however upon doing the command;
    dnf system-upgrade reboot
    it still says system is not ready for upgrade.
    How can I upgrade this without having to download the whole 1.8gb again for the fourth time? (firs time gui software manager failed, second time cli complained over fedora keys, now third time as per above)....
    I cant see any help on the fedora wiki on how to overcome this particular issue. is it just "dnf fedora-upgrade"?
    Thanks in advance!
    Feb 2013
    England
    369
    Re: Unusual upgrade problem?
    The way I read it, you cant continue unless you download it all again, which makes it saving the cache a total waste of time and space! Also, what do you think this bit means and is it importat?
    "warning: /var/lib/dnf/system-upgrade/libde265-1.0.2-8.fc28.i686.rpm: Header V4 RSA/SHA1 Signature, key ID 09eab3f2: NOKEY
    Curl error (37):"
    PabloTwo's Avatar
    Mar 2007
    Seville, FL
    7,765
    Linux Chrome 68.0.3440.84
    Try,
    # rpm --import /etc/pki/rpm-gpg/RPM-GPG-KEY-rpmfusion-free-fedora-28-primary
    # rpm --import /etc/pki/rpm-gpg/RPM-GPG-KEY-rpmfusion-nonfree-fedora-28-primary
    Are you attempting a system-upgrade from F27 to F28?
    Feb 2013
    England
    369
    f25 to f28.
    The import commands you mention, I did try, but they failed.
    Dec 2017
    Sosnowiec, PL
    36
    31
    Linux Firefox 61.0
    Then you should import these gpg keys as ROOT by command:
    rpm --import /path/to/GPG-KEY
    Re-run upgrade command.
    marcin82
    Feb 2013
    England
    369
    I was root..
    This has failed too! :-
    error: /path/to/GPG-KEY: import read failed(2).
    Feb 2013
    England
    369
    If I cant upgrade without having to download again, I may as well download the iso.
    Feb 2013
    England
    369
    well from what I have read on the internet this is likely from rpm fusion because a lot of others using rpm fusion have this error.
    Feb 2013
    England
    369
    I'll give this cli one more try, afterall only time wasted lol.
    I've removed fusion free and non free, but still am concerned about this line;
    Apr 2009
    central NY, USA
    1,105
    You did substitute the correct path for /path/to/GPG-KEY ?.
    Change - the only constant.
    Feb 2013
    England
    369
    Linux (Android 5.1.1) Chrome 67.0.3396.87
    Quote Originally Posted by lightman47
    Lol no I didn't..
    Anyhow I've downloaded the iso and installed from a disc now since I couldn't find a way to upgrade without downloading it all again. I hope things have improved in another two years time where I'm forced to update everything again. Shame developers don't think of wasted time downloading and the fact there was no error messages or instructions on why the update couldn't Contin.
    Apr 2009
    central NY, USA
    1,105
    Not thinking a Fedora problem per se, rather maybe package/repo/other issue. After all, it was only a missing GPG key from the package.
    -my 2 cents (I am NO expert by any means).
    Apr 2018
    Finland
    68
    Linux (Fedora) Chrome 67.0.3396.79
    Quote Originally Posted by yellowsubmarine
    Lol no I didn't..
    I'm completely noob to linux, but I think problem was just like other said. You didn't had the gpg key thing.
    The error:
    probably occurred because file didn't exist or symlink to the "/etc/pki/rpm-gpg/RPM-GPG-KEY-rpmfusion-free-fedora-28-primary" file was missing.
    Maybe it was problem with file names. Since default ones in /etc/pki end to something like "*-primary" and manually downloaded doesn't have that extension
  1. Unusual Fedora problem
    By GCFreak in forum Using Fedora
    Last Post: 28th October 2008, 08:19 AM
  2. A unusual grub problem
    By snowball in forum Using Fedora
    Last Post: 28th October 2006, 06:07 AM
  3. an unusual problem
    By Smartistic in forum Installation, Upgrades and Live Media
    Last Post: 7th July 2006, 01:39 PM
  4. Unusual sound problem on FC2?
    By guy in forum EOL (End Of Life) Versions
    Last Post: 10th June 2005, 09:18 PM
