Driver for realtek RTL8723BS wifi/bluetooth chip
Results 1 to 15 of 15
    Ukraine
    18
    Hello everyone.
    I had installed Fedora 28 to the lynx7 tablet. This tablet has the realtek RTL8723BS wifi/bluetooth chip.
    Everything including wifi work fine except that there isn't any bluetooth adapter in the system.
    bt-adapter -l finds nothing.
    Fedora automatically loads the r8723bs kernel module but does not load any bluetooth related modules.
    lsmod | grep -E 'bluetooth|bt' shows nothing.
    I gathered all data about the problem here: http://vps2.happyuser.info/lynx7-problem
    I think perhaps the r8723bs module is bad or very old and is not fully compatible with modern linux.
    What can I do?
    Mar 2017
    103
    Re: Driver for realtek RTL8723BS wifi/bluetooth chip
    I had that chipset when my notebook was new (see my username). I had to use an experimental driver from GIT. It worked, but it still didn't perform well, so I threw it away and got an Intel 8265.
    If you want to try to get the development version of the driver, look for it under lfinger (the username of the developer).
    Tim
    Ukraine
    18
    Quote Originally Posted by tim8723
    Tim, where can I get the development version of the driver?
    I found this app only: https://github.com/lwfinger/rtl8723bs_bt
    and it does not work.
    In start_bt.sh I changed the line
    ./rtk_hciattach -n -s 115200 $TTY rtk_h5 > hciattach.txt 2>&1 &
    to
    for easy output view.
    The /dev/ttyS4 does not exist on the tablet.
    root@lynx7:~# ls /dev/ttyS4
    ls: cannot access '/dev/ttyS4': No such file or directory
    root@lynx7:/home/sergiy/rtl8723bs_bt# ./start_bt.sh
    Using device /dev/ttyS4 for Bluetooth
    Can't open serial port: No such file or directory
    Can't initialize device: No such file or directory
    With /dev/ttyS5 this app does not work.
    root@lynx7:/home/sergiy/rtl8723bs_bt# ./start_bt.sh ttyS5
    Using device /dev/ttyS5 for Bluetooth
    Realtek Bluetooth init uart with init speed:115200, final_speed:115200, type:HCI UART H5
    Realtek Bluetooth :Realtek hciattach version 2.5
    Realtek Bluetooth :3-wire sync pattern resend : 1, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 2, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 3, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 4, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 5, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 6, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 7, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 8, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 9, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 10, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 11, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 12, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 13, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 14, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 15, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 16, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 17, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 18, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 19, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 20, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 21, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 22, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 23, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 24, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 25, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 26, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 27, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 28, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 29, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 30, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 31, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 32, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 33, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 34, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 35, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 36, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 37, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 38, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 39, len: 8
    Realtek Bluetooth :3-wire sync pattern resend : 40, len: 8
    Realtek Bluetooth ERROR: H5 sync timed out
    I tried the both firmwares rtlbt_fw and rtlbt_fw_new.
    It is weird that I can see ttyS4 in dmesg but the /dev/ttyS4 file does not exist.
    root@lynx7:~# dmesg | grep ttyS
    [    1.677076] 00:02: ttyS0 at I/O 0x3f8 (irq = 27, base_baud = 115200) is a 16550A
    [    1.703273] 80860F0A:00: ttyS4 at MMIO 0x50d47000 (irq = 17, base_baud = 2764800) is a 16550A
    [    1.703558] serial serial0: tty port ttyS4 registered
    [    1.716888] 80860F0A:01: ttyS5 at MMIO 0x50d4d000 (irq = 18, base_baud = 2764800) is a 16550A
    Ukraine
    18
    I think perhaps the /dev/ttyS5 is not related to the RTL8723BS device.
    root@lynx7:~# udevadm info /dev/ttyS5
    P: /devices/platform/80860F0A:01/tty/ttyS5
    N: ttyS5
    E: DEVNAME=/dev/ttyS5
    E: DEVPATH=/devices/platform/80860F0A:01/tty/ttyS5
    E: ID_MM_CANDIDATE=1
    E: MAJOR=4
    E: MINOR=69
    E: SUBSYSTEM=tty
    E: TAGS=:systemd:
    E: USEC_INITIALIZED=8295930
    root@lynx7:~# udevadm info -a /dev/ttyS5
      looking at device '/devices/platform/80860F0A:01/tty/ttyS5':
        KERNEL=="ttyS5"
        SUBSYSTEM=="tty"
        DRIVER==""
        ATTR{close_delay}=="50"
        ATTR{closing_wait}=="3000"
        ATTR{custom_divisor}=="0"
        ATTR{flags}=="0x39000000"
        ATTR{io_type}=="3"
        ATTR{iomem_base}=="0x50D4D000"
        ATTR{iomem_reg_shift}=="2"
        ATTR{irq}=="18"
        ATTR{line}=="5"
        ATTR{port}=="0x0"
        ATTR{rx_trig_bytes}=="8"
        ATTR{type}=="4"
        ATTR{uartclk}=="1843200"
        ATTR{xmit_fifo_size}=="64"
      looking at parent device '/devices/platform/80860F0A:01':
        KERNELS=="80860F0A:01"
        SUBSYSTEMS=="platform"
        DRIVERS=="dw-apb-uart"
        ATTRS{driver_override}=="(null)"
      looking at parent device '/devices/platform':
        KERNELS=="platform"
        SUBSYSTEMS==""
        DRIVERS==""
    Mar 2017
    103
    Oh , gosh, I'm sorry. I don't remember that level of detail. It was almost two years ago when I went through all that.
    But, I think you have found what you need. I wish I could be more help.
    Tim
    Ukraine
    18
    http://vps2.happyuser.info/lynx7-pro...bs-modinfo.txt
    The r8723bs module is from realtek corporation.
    Maybe I need to blacklist the r8723bs module and try to configure the loading of some other modules? What?
    6,799
    Linux Firefox 61.0
    You may need to compile this for bluetooth support as it is clearly not included in the 8723BS module merged into the linux kernels, instructions are in the readme at the bottom of the page:
    Ukraine
    18
    Dear antikythera, of course I compiled the rtk_hciattach program. I cloned that git repo and issued the following commands from the rtl8723bs_bt directory:
    make
    sudo make install
    Maybe the r8723bs module uses the wrong firmware? How to determine what firmware file is used by that module?
    6,799
    Linux Firefox 61.0
    please send all this information to the upstream kernel team by emailing the wireless mailing list, they should be able to help you further:
    mailto:linux-wireless@vger.kernel.org
    Ukraine
    18
    I had sent the email there. Thank you very much.
    Feb 2019
    Poland
    Linux Firefox 65.0
    Originally posted there, but maybe you can help me with my RTL8723BS, the issue is that it can't see any SSID. Linux driver seems to work correctly, so the question is if module parameters are set correctly. If you have working RTL8723BS it would be nice to compare these parameters from working devices. Also possibly it could help answer if there is a bug in current driver implementation.
    Ukraine
    18
    Linux (Fedora) Firefox 65.0
    Hi.
    In 4.20.6 kernel the RTL8723BS chip in my tablet works normally. The wifi and bluetooth works.
    Please explain what I have to do.
    6,799
    Windows NT 10.0 Chrome 72.0.3626.96
    Quote Originally Posted by itknight
    Have you tried entering the SSID manually in Network Manager? If so does the adaptor then connect properly to the network?
    Ukraine
    18
    It seem like the manual connection to wifi network dont work.
    I created the new wifi connection and entered the SSID of my ADSL router.
    Then I clicked "connect to hidden wifi network" in networkmanager and selected the connection I created before.
    And nothing happened. The connection had not established. It even did not ask the password for wifi.
    I did not get any error message.
    I attempted twice.
    6,799
    Linux Firefox 65.0
    that was addressed at itknight, but presumably given the lack of response they had the same outcome as you when they tried
    WIFI & rtl8723 chip
    By didier83 in forum Servers & Networking
    Last Post: 19th February 2017, 11:25 PM
  2. Error compiling driver for Ralink 5392sta WiFi chip
    By Linux Fan Boi in forum Servers & Networking
    Last Post: 1st September 2013, 10:35 AM
  3. no networking with realtek 8101E/8102E chip
    By undernet in forum Hardware & Laptops
    Last Post: 5th August 2012, 05:52 PM
  4. Asus Wifi-AP Solo with rtl8187 chip
    By baysailor in forum Installation, Upgrades and Live Media
    Last Post: 12th November 2006, 07:31 PM
