Wifi networks not detected
    Oct 2015
    Rome
    12
    Linux Chrome 66.0.3359.170
    Hello everybody. I have a Dell XPS13 with a broadcom wifi card. Right out of the box, the card was not recognized and I could not see the wifi entry in Network Manager; then I installed broadcom-STA and akmod and after that everything was fine, I've had no problems at all for several months. All of a sudden Network Manager stopped detecting networks. I can see the WiFi option in Network Manager, but when I hit on "Select network" it opens the windows, starts searching and hangs there forever without finding any. I am using kernel 4.16.12-300, but the problems is not solved booting with an older kernel. Any suggestion?
    964
    Re: Wifi networks not detected
    See if this helps: https://forums.fedoraforum.org/showt...are-repository
    you will need to download the latest ".hcd" file from that brcm link in github, and place it into the /lib/firmware/brcm/ folder. then reboot.
    Oct 2015
    Rome
    12
    Linux (Fedora) Chrome 67.0.3396.62
    I downloaded the file but when I turned the laptop on the network was detected. I don't know what's happened, is there a way to traceback the error? I'll save your suggestion in case the problem pops up again. Thanks for your help!
  1. Replies: 6
    Last Post: 13th April 2014, 04:51 AM
  2. Replies: 44
    Last Post: 12th December 2011, 08:42 PM
  3. F12 wireless networks not detected
    By aghatpan in forum EOL (End Of Life) Versions
    Last Post: 28th April 2011, 08:38 AM
  4. F12 wireless networks not detected
    By aghatpan in forum Hardware & Laptops
    Last Post: 28th April 2011, 06:48 AM
  5. no wifi networks any more
    By BehindTheTruth in forum Servers & Networking
    Last Post: 20th June 2008, 10:38 PM
